New Hoosiers and my suspension, What is going on? |
ww914 |
Mar 23 2013, 07:46 PM
914 Convert Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California |
Today at the track, with my new Hoosier A6's, I was lifting the inside front tire. I had installed 180 lb springs, took off the rear sway bar and tightened up the front 19mm Tarrett just a little. Everyone at the track told me that I needed beefier springs in the back. Well, I have 220 lbs springs, shall I try them? Shall I leave the sway bar off? Should I soften or tighten the front sway bar? Oh, I am running 205/15 on 5.5 rims. I am looking at 7" rims to get the patch better. Any other recommendations?
ChrisFoley |
Apr 7 2013, 08:50 AM
I am Tangerine Racing Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Are you allowed to slot the strut towers to get more negative camber up front?
What's your ride height? Lowering the car a quarter inch will give you more negative camber. Did you make your measurements with your weight in the drivers seat? I would start with the a/s bar adjusted to the middle. I would set toe at zero front and rear. Toe in at the front is fine to compensate for stock tie-rods but doesn't benefit handling. Toe out at the front improves turn in at the expense of high speed stability. Toe in at the rear reduces oversteer, especially with a higher powered engine. Toe out at the rear will make the car spin easily. |
Lo-Fi Version | Time is now: 26th June 2024 - 09:24 AM |
