john_g |
Member ![]() ![]() Group: Members Posts: 110 Joined: 1-November 12 From: british columbia Member No.: 15,100 Region Association: Canada ![]() |
Hey, guys, I'm curious about an interesting coincidence. My latest 914 is relatively new to me. When I purchased it, I noticed that it missed significantly at higher revs, especially in the lower gears. The owner said that it there was a rev limiter in the electronic ignition, but I knew that was BS because I removed the dizzie cap and saw that it had the normal rotor w/o the rev limiter, and also because I never ran it even close to the red line. The other issue I noted was that the #3 cylinder's compression was significantly lower than the other cylinders, but of course I assumed these two issues were unrelated.
When I got it home I found that the spark wire connection at the distributor cap for the #3 cylinder was very poor. As soon as I replaced the spark wires the problem of the engine missing stopped. This has got me thinking. Obviously, from what the PO said, the missing (and the bad spark connection at #3) had been going on for a while. Is it possible that running the car for a long time w/ poor spark at one cylinder could lower compression, through incomplete combustion, unburned gas, etc? And ... if the cylinder and valves are gummed up from this, could I expect that the compression could increase after some lengthy drives and cleaner combustion? |
flash914 |
Member ![]() ![]() Group: Members Posts: 124 Joined: 1-January 11 From: littlerock CA Member No.: 12,554 Region Association: Southern California ![]() |
Yes and No. The term is ring wash. If the unburnt gas end up diluting the oil on the cylinders it becomes metal to metal and the rings/ cylinders go away. A miss like this or a over rich carb can also cause this. Give it some time and it may come back around or? Gordon
john_g |
Yes and No. The term is ring wash. If the unburnt gas end up diluting the oil on the cylinders it becomes metal to metal and the rings/ cylinders go away. A miss like this or a over rich carb can also cause this. Give it some time and it may come back around or? Gordon Thanks. Actually, that's what my first thought was - that the rich mixture would dilute the oil and cause wear - which isn't good and isn't reversible w/o a rebuild. Nevertheless, I'm going to monitor it, run it, change oil and adjust the valves more frequently in the hopes that I might clean things out and have some improvement. The compression in #3 is currently 115. |
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
Yes and No. The term is ring wash. If the unburnt gas end up diluting the oil on the cylinders it becomes metal to metal and the rings/ cylinders go away. A miss like this or a over rich carb can also cause this. Give it some time and it may come back around or? Gordon Thanks. Actually, that's what my first thought was - that the rich mixture would dilute the oil and cause wear - which isn't good and isn't reversible w/o a rebuild. Nevertheless, I'm going to monitor it, run it, change oil and adjust the valves more frequently in the hopes that I might clean things out and have some improvement. The compression in #3 is currently 115. WOW, 115 is pretty good compression (for "significantly lower"). If that is low what are the others? Jim |
john_g |
Yes and No. The term is ring wash. If the unburnt gas end up diluting the oil on the cylinders it becomes metal to metal and the rings/ cylinders go away. A miss like this or a over rich carb can also cause this. Give it some time and it may come back around or? Gordon Thanks. Actually, that's what my first thought was - that the rich mixture would dilute the oil and cause wear - which isn't good and isn't reversible w/o a rebuild. Nevertheless, I'm going to monitor it, run it, change oil and adjust the valves more frequently in the hopes that I might clean things out and have some improvement. The compression in #3 is currently 115. WOW, 115 is pretty good compression (for "significantly lower"). If that is low what are the others? #1 - 120 #2 - 125 #3 - 115 #4 - 140!!!!!!! 25 lb diff between lowest and highest ain't too good, is it? To me, that's makes it dodgy, as the Brits say. Jim |
Lo-Fi Version | Time is now: 26th June 2024 - 02:39 AM |
