> oil pooling on engine tin
ericoneal
post Apr 14 2013, 08:13 PM
I seem to have a problem with oil pooling on the top of the engine tin, where the red circle is. Just changed the valve cover, and its dry, so I know somehow its not coming from there. I wonder if its coming from the little hose just to the upper left? BUt thats dry too. At a loss here...Attached Image
euro911
post Apr 14 2013, 11:56 PM
If the leak started recently after changing the VC gaskets, I'd agree that's where you need to focus.
Crank case pressure is probably pushing the oil out of the top of the gasket.
ericoneal   oil pooling on engine tin   Apr 14 2013, 08:13 PM
mepstein   Do you have an oil bath air filter? When I jack up...   Apr 14 2013, 08:21 PM
JamesM   Do you have an oil bath air filter? When I jack u...   Apr 14 2013, 10:24 PM
JamesM   also.... where do you have that head vent hose con...   Apr 14 2013, 10:28 PM
jsconst   I had the same problem, ended up coming from the t...   Apr 14 2013, 11:26 PM
r_towle   Head vent   Apr 14 2013, 11:35 PM
ericoneal   Winner! For the record, the head vent hose wa...   May 1 2013, 08:24 PM
euro911   If the leak started recently after changing the VC...   Apr 14 2013, 11:56 PM
ericoneal   The leak was happening before I changed the VC gas...   Apr 15 2013, 08:13 AM
JamesM   Ok, so now I am confused as the 1st pic was from a...   Apr 15 2013, 11:18 AM
Vacca Rabite   Ok, so now I am confused as the 1st pic was from ...   Apr 15 2013, 11:35 AM
JamesM   Ok, so now I am confused as the 1st pic was from...   Apr 15 2013, 05:09 PM
The Cabinetmaker   Oil can and will blow out the top of the valve cov...   Apr 15 2013, 08:53 AM
ericoneal   I will have another look, but I just changed the g...   Apr 15 2013, 09:30 AM
rhodyguy   have you cleaned the interior of the breather box....   Apr 15 2013, 08:54 AM
ericoneal   Havent touched it, the previous owner had it on th...   Apr 15 2013, 09:30 AM
brant   valve cover   Apr 15 2013, 08:55 AM
The Cabinetmaker   His second pic says its not his engine   Apr 15 2013, 11:58 AM
rhodyguy   the bb is not a sealed container. when you remove ...   Apr 15 2013, 12:48 PM
jsconst   I'm still saying valve cover, since that's...   Apr 15 2013, 07:42 PM
14 User(s) are reading this topic (14 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 8th January 2025 - 01:34 AM
