> oil pooling on engine tin
ericoneal
post Apr 14 2013, 08:13 PM
I seem to have a problem with oil pooling on the top of the engine tin, where the red circle is. Just changed the valve cover, and its dry, so I know somehow its not coming from there. I wonder if its coming from the little hose just to the upper left? BUt thats dry too. At a loss here...Attached Image
brant
post Apr 15 2013, 08:55 AM
valve cover
ericoneal   oil pooling on engine tin   Apr 14 2013, 08:13 PM
mepstein   Do you have an oil bath air filter? When I jack up...   Apr 14 2013, 08:21 PM
JamesM   Do you have an oil bath air filter? When I jack u...   Apr 14 2013, 10:24 PM
JamesM   also.... where do you have that head vent hose con...   Apr 14 2013, 10:28 PM
jsconst   I had the same problem, ended up coming from the t...   Apr 14 2013, 11:26 PM
r_towle   Head vent   Apr 14 2013, 11:35 PM
ericoneal   Winner! For the record, the head vent hose wa...   May 1 2013, 08:24 PM
euro911   If the leak started recently after changing the VC...   Apr 14 2013, 11:56 PM
ericoneal   The leak was happening before I changed the VC gas...   Apr 15 2013, 08:13 AM
JamesM   Ok, so now I am confused as the 1st pic was from a...   Apr 15 2013, 11:18 AM
Vacca Rabite   Ok, so now I am confused as the 1st pic was from ...   Apr 15 2013, 11:35 AM
JamesM   Ok, so now I am confused as the 1st pic was from...   Apr 15 2013, 05:09 PM
The Cabinetmaker   Oil can and will blow out the top of the valve cov...   Apr 15 2013, 08:53 AM
ericoneal   I will have another look, but I just changed the g...   Apr 15 2013, 09:30 AM
rhodyguy   have you cleaned the interior of the breather box....   Apr 15 2013, 08:54 AM
ericoneal   Havent touched it, the previous owner had it on th...   Apr 15 2013, 09:30 AM
brant   valve cover   Apr 15 2013, 08:55 AM
The Cabinetmaker   His second pic says its not his engine   Apr 15 2013, 11:58 AM
rhodyguy   the bb is not a sealed container. when you remove ...   Apr 15 2013, 12:48 PM
jsconst   I'm still saying valve cover, since that's...   Apr 15 2013, 07:42 PM
12 User(s) are reading this topic (12 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 8th January 2025 - 01:32 AM
