Done with the motor and tranny, NOT heading down route 66 - Dilivar Strikes |
worn |
Apr 8 2013, 11:00 AM
can't remember Group: Members Posts: 3,193 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
In a few threads I have asked for and received advice. Here is the outcome:
Engine built from 1.7 to 2056. Tranny completely rebuilt. New synchs, new bearings, new seals. ARP rod bolts, a webcam, 8.4:1 compression. I am adding a direct gauge in addition to the vdo at the dash. AFM and CHT will go with them. But, I am taking the 911 down Route 66. I am leaving in a couple of weeks and don't have time to get the new engine swapped into the teener. I am driving from Madison WI as far as Albuquerque NM. Then back through the western rockies. Any suggestions? Also, a collection of shops might come in handy. Thanks everyone. Especially parts suppliers such as Valy and Rhody Guy. I have photos of the whole thing, so if anyone is interested I could make a thread. |
TheCabinetmaker |
Apr 14 2013, 05:36 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I broke mine in at musr 2011. Drive it to Tulsa. We'll readjust the valves, change the oil, check it over and get you on your way.
worn |
Apr 15 2013, 09:39 AM
I broke mine in at musr 2011. Drive it to Tulsa. We'll readjust the valves, change the oil, check it over and get you on your way. Well, the big question is how hard will it be to tune the 2056 with the stock EFI. If it will just run after basic timing etc, then it is worth a shot. But if I have to take apart a MAP sensor to get it right I may not have time. (IMG:style_emoticons/default/idea.gif) |
Bleyseng |
Apr 15 2013, 09:54 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
I broke mine in at musr 2011. Drive it to Tulsa. We'll readjust the valves, change the oil, check it over and get you on your way. Well, the big question is how hard will it be to tune the 2056 with the stock EFI. If it will just run after basic timing etc, then it is worth a shot. But if I have to take apart a MAP sensor to get it right I may not have time. (IMG:style_emoticons/default/idea.gif) Depends on the cam used. If its a stock cam no problem, but if its non stock you must adjust the MPS to reset the AFR. |
worn |
Apr 15 2013, 02:14 PM
I broke mine in at musr 2011. Drive it to Tulsa. We'll readjust the valves, change the oil, check it over and get you on your way. Well, the big question is how hard will it be to tune the 2056 with the stock EFI. If it will just run after basic timing etc, then it is worth a shot. But if I have to take apart a MAP sensor to get it right I may not have time. (IMG:style_emoticons/default/idea.gif) Depends on the cam used. If its a stock cam no problem, but if its non stock you must adjust the MPS to reset the AFR. I have an extra sensor that has had the epoxy removed and still holds vacuum. Should I find an inductance meter? |
Lo-Fi Version | Time is now: 26th June 2024 - 11:22 AM |
