Matt Romanowski |
Senior Member ![]() ![]() ![]() Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 ![]() |
This weekend after a 40 minute stint on the track, we saw our transmission temps getting to 247F. That is on a day were it was about 45F ambient and we had the pump and cooler running.
Doing some research, the answers I've heard on safe temperatures are all over. The oil is good to 300F according to the manufacturer and some folks say they run there, but that seems really hot. Most folks say they like to be around 225F. We just rebuilt the transmission and set the R+P to the factory backlash setting of .007", but we're going to open the transmission up and loosen things up a bit. ![]() |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,641 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
remind me...
how much motor/torque are you running? I have lost 3 in about 3 years, but everyone of mine has been the intermediate plate bearing... |
Matt Romanowski |
remind me... how much motor/torque are you running? I have lost 3 in about 3 years, but everyone of mine has been the intermediate plate bearing... Stock 3 liter but it's always a 2 driver car. We killed the main shaft and pinion shaft bearings as well. As an FYI, pinion shaft bearings are getting really hard to find. |
crresind |
Newbie ![]() Group: Members Posts: 13 Joined: 8-June 04 From: Oceanside, California Member No.: 2,175 Region Association: Southern California ![]() |
The problem is not the 'tight' backlash, it is the 3 liters pushing it. If you do not like the damage that you are seeing now, just wait until you see the damage from 'loosening' the backlash. Porsche changed to the 915 trans when they went from 2.0/2.2l to 2.4l in 1972. That is the tip off. When we look at what the factory used in racing back in the day, the '901' really did not make it very long, especially as the engines got bigger. I have seen folks with 2.4/2.7l cars go through gears annually when used on the track regularly.
Lo-Fi Version | Time is now: 18th June 2024 - 07:17 AM |
