Disconnected battery cable and reconnected, now starter wont engage |
ericoneal |
Apr 16 2013, 06:44 PM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I disconected the positive (and neg) cables. Reconnected, and now the car wont start. (IMG:style_emoticons/default/mad.gif) The dash lights and fuel pump come on, headlights are bright, battery is fully charged, but no click or anything. I checked all of the fuses under the steering wheel and 3 of them on the firewall by the battery and all are good.
Are there other fuses that I am missing? SHe has always fired up, really frustrated.... |
Mike Bellis |
Apr 16 2013, 08:52 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Did you clean the battery cables and battery terminals?
Both can and do get glazed over with time. It is possible you have a bad connection even if it is tight. Use a wire brush or sand paper on all connections and try again. |
Rand |
Apr 16 2013, 09:06 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Did you clean the battery cables and battery terminals? Both can and do get glazed over with time. It is possible you have a bad connection even if it is tight. Use a wire brush or sand paper on all connections and try again. (IMG:style_emoticons/default/agree.gif) That's what I was going to suggest. Clean both the posts and the insides of the connector clamps. I prefer using one of those little brush/scraper tools that's made for it. A majority of the time when you have some electrical working but it won't crank, and especially if you hear a starter solenoid click, a dirty battery connection is the culprit. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.americantechnology.co.uk-3573-1366167978.1.jpg) |
Lo-Fi Version | Time is now: 6th January 2025 - 10:22 PM |
