Disconnected battery cable and reconnected, now starter wont engage |
ericoneal |
Apr 16 2013, 06:44 PM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I disconected the positive (and neg) cables. Reconnected, and now the car wont start. (IMG:style_emoticons/default/mad.gif) The dash lights and fuel pump come on, headlights are bright, battery is fully charged, but no click or anything. I checked all of the fuses under the steering wheel and 3 of them on the firewall by the battery and all are good.
Are there other fuses that I am missing? SHe has always fired up, really frustrated.... |
Mike Bellis |
Apr 16 2013, 08:52 PM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Did you clean the battery cables and battery terminals?
Both can and do get glazed over with time. It is possible you have a bad connection even if it is tight. Use a wire brush or sand paper on all connections and try again. |
Rand |
Apr 16 2013, 09:06 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Did you clean the battery cables and battery terminals? Both can and do get glazed over with time. It is possible you have a bad connection even if it is tight. Use a wire brush or sand paper on all connections and try again. (IMG:style_emoticons/default/agree.gif) That's what I was going to suggest. Clean both the posts and the insides of the connector clamps. I prefer using one of those little brush/scraper tools that's made for it. A majority of the time when you have some electrical working but it won't crank, and especially if you hear a starter solenoid click, a dirty battery connection is the culprit. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.americantechnology.co.uk-3573-1366167978.1.jpg) |
ericoneal |
Apr 17 2013, 06:55 AM
The starter is not clicking, the lights on the dash are on, but when i turn the key, they all go out and nothing happens. I'm sure there has to be something disconnected somewhere.... I'm also going to put in the battery from my daily driver and try as well..
Really need to get this thing started, we are moving in a couple of weeks. (IMG:style_emoticons/default/blink.gif) Did you clean the battery cables and battery terminals? Both can and do get glazed over with time. It is possible you have a bad connection even if it is tight. Use a wire brush or sand paper on all connections and try again. (IMG:style_emoticons/default/agree.gif) That's what I was going to suggest. Clean both the posts and the insides of the connector clamps. I prefer using one of those little brush/scraper tools that's made for it. A majority of the time when you have some electrical working but it won't crank, and especially if you hear a starter solenoid click, a dirty battery connection is the culprit. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.americantechnology.co.uk-3573-1366167978.1.jpg) |
Lo-Fi Version | Time is now: 6th January 2025 - 09:56 PM |
