Disconnected battery cable and reconnected, now starter wont engage |
ericoneal |
Apr 16 2013, 06:44 PM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I disconected the positive (and neg) cables. Reconnected, and now the car wont start. (IMG:style_emoticons/default/mad.gif) The dash lights and fuel pump come on, headlights are bright, battery is fully charged, but no click or anything. I checked all of the fuses under the steering wheel and 3 of them on the firewall by the battery and all are good.
Are there other fuses that I am missing? SHe has always fired up, really frustrated.... |
stugray |
Apr 17 2013, 06:36 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
QUOTE Have you tried to jump the solenoid? That was my first thought just stick a screw driver across both terminals (what I would do) But here's the right way for those scared of that: 1 - use an idiot light and see if you have voltage at the starter 2 - use the idiot light to see if you get voltage at the solenoid when someone turns the key If yes to both, it is wired and you havent blown a fuse. 3 - Put a voltmeter across your battery while turning the key. If voltage drops significantly (below ~11) then you have a bad battery or the starter/solenoid has a short. If the voltage at the battery stays up (>12) the battery is good and your connection to the starter is poor 4 - Put a voltmeter across the starter while turning the key. If it stays high, your starter is bad HTH Stu EDIT - just read where you are not even hearing a faint click, so #4 is unlikely (steps are still all good though) |
Lo-Fi Version | Time is now: 6th January 2025 - 10:13 PM |
