Disconnected battery cable and reconnected, now starter wont engage |
ericoneal |
Apr 16 2013, 06:44 PM
Member Group: Members Posts: 320 Joined: 13-August 12 From: Crestwood, KY Member No.: 14,795 Region Association: South East States |
I disconected the positive (and neg) cables. Reconnected, and now the car wont start. (IMG:style_emoticons/default/mad.gif) The dash lights and fuel pump come on, headlights are bright, battery is fully charged, but no click or anything. I checked all of the fuses under the steering wheel and 3 of them on the firewall by the battery and all are good.
Are there other fuses that I am missing? SHe has always fired up, really frustrated.... |
ericoneal |
Apr 18 2013, 07:11 PM
It worked! The starter turned and it sparked all to be damned. So this is telling me that the relay is bad, or its just not getting enough power because my red wires from the battery may be too crusty?
Rand |
Apr 18 2013, 08:23 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
It worked! The starter turned and it sparked all to be damned. So this is telling me that the relay is bad, or its just not getting enough power because my red wires from the battery may be too crusty? Well, it ruled out a hell of a lot of troubleshooting crap for sure. I think it is either a cracked ignition switch, or a bad connection at all that stupid seatbelt relay junk under your passenger seat. Which by the way, you can eliminate. Just cut all that crap out, join any brown wires (which are grounds) and don't worry about the rest, just make sure they are taped off so they can't touch anything. The most IMPORTANT key is joining the connections to the starter circuit. Which means join the big yellow wires. THAT is all it needs. |
Lo-Fi Version | Time is now: 6th January 2025 - 10:11 PM |
