> Disconnected battery cable and reconnected, now starter wont engage
ericoneal
post Apr 16 2013, 06:44 PM
I disconected the positive (and neg) cables. Reconnected, and now the car wont start. (IMG:style_emoticons/default/mad.gif) The dash lights and fuel pump come on, headlights are bright, battery is fully charged, but no click or anything. I checked all of the fuses under the steering wheel and 3 of them on the firewall by the battery and all are good.
Are there other fuses that I am missing? SHe has always fired up, really frustrated....
Tom
post Apr 19 2013, 12:19 PM
ericoneal,
Glad you found the reason why your car was not starting.
The reason why your car had the relay there is because some previous owner most likely had the dreaded hot-no-start problem many bugs and 914 develop as they age. The starting circuit is a long one with many connections and has a high demand on the battery voltage to initially close the solenoid. It takes close to 8.5 to 9 volts for the starter solenoid to close. Given that these cars are getting older, it is no surprise that more and more have starting issues. Electrical components, wires included, increase resistance over time and especially when heat is applied. Since a large part of the electrical system is in the engine bay, it gets a lot of heat. Resistance in the connections and wire causes voltage drop in the circuit. When it reaches 3-4 volts drop, the solenoid won't operate and you have the dreaded hot-no-start issues.
I would normally agree with leaving the relay out as simple circuits will usually outperform complex circuits, except this circuit was designed about 50-60 years ago and even the factory recognized the problems and VW at least issued a fix with a starter relay kit.
Bottom line, if yours works OK without the relay, leave it out. Your car had the problem in the past so just be aware that when it gets hot out it could reappear.
Tom
ericoneal   Disconnected battery cable and reconnected   Apr 16 2013, 06:44 PM
jsconst   My starter used to do the same thing,(have a diffe...   Apr 16 2013, 06:51 PM
914itis   Are you sure you connected back the ground wire to...   Apr 16 2013, 07:03 PM
ericoneal   I havent touched the transmission at all. All I d...   Apr 16 2013, 07:07 PM
914itis   I havent touched the transmission at all. All I ...   Apr 16 2013, 07:17 PM
ericoneal   The ground wires near the battery seem tight. Sho...   Apr 16 2013, 07:38 PM
ericoneal   That did nothing. Its got to be something with th...   Apr 16 2013, 07:09 PM
ThePaintedMan   That did nothing. Its got to be something with t...   Apr 16 2013, 07:13 PM
struckn   Partially fried ignition switch? :idea:   Apr 16 2013, 07:12 PM
Elliot Cannon   Reach in and tap the solenoid (lightly).   Apr 16 2013, 07:41 PM
jsconst   Reach in and tap the solenoid (lightly). :agree...   Apr 16 2013, 08:02 PM
kg6dxn   Did you clean the battery cables and battery termi...   Apr 16 2013, 08:52 PM
Rand   Did you clean the battery cables and battery term...   Apr 16 2013, 09:06 PM
ericoneal   The starter is not clicking, the lights on the das...   Apr 17 2013, 06:55 AM
Jeff Hail   Its the gremlinector.   Apr 16 2013, 09:36 PM
Cupomeat   Turn the headlights on, then try to start the car....   Apr 17 2013, 07:07 AM
The Cabinetmaker   Turn the headlights on, then try to start the car...   Apr 17 2013, 07:16 AM
ericoneal   OK. Just checked again. Put the battery from my ...   Apr 17 2013, 05:37 PM
kg6dxn   OK. Just checked again. Put the battery from my...   Apr 17 2013, 09:20 PM
ericoneal   "In that picture, the red wire is the starter...   Apr 18 2013, 10:19 AM
The Cabinetmaker   Have you tried to jump the solenoid?   Apr 17 2013, 07:20 AM
ThePaintedMan   Hard to tell from just a picture, but it sure look...   Apr 17 2013, 05:55 PM
ericoneal   Tried the key both ways, jiggled. I dont think it...   Apr 17 2013, 06:22 PM
turk22   When I had a similar problem, it was because the R...   Apr 17 2013, 06:31 PM
stugray   That was my first thought just stick a screw driv...   Apr 17 2013, 06:36 PM
ericoneal   1 and 2 are both getting power and I have tried 2 ...   Apr 17 2013, 06:59 PM
Tom   Check the condition of the 4 red wires' connec...   Apr 18 2013, 10:21 AM
Tom   The little black box is a ford starter relay. Simp...   Apr 18 2013, 10:41 AM
rpmmaxxed   I have had this happen to my car a number of times...   Apr 18 2013, 12:15 PM
ericoneal   Thanks guys, I will try both of all of these tonig...   Apr 18 2013, 12:29 PM
Rand   It only takes a minute to jump the solenoid as sug...   Apr 18 2013, 12:30 PM
ericoneal   It only takes a minute to jump the solenoid as su...   Apr 18 2013, 01:01 PM
The Cabinetmaker   thank you Rand. I really didn't want to go dig...   Apr 18 2013, 12:32 PM
Jeffs9146   I have had one of the smaller red wires fall down ...   Apr 18 2013, 01:20 PM
bandjoey   To save your lifego to FLAPS and get a hand starte...   Apr 18 2013, 02:58 PM
ericoneal   Will do To save your lifego to FLAPS and get...   Apr 18 2013, 05:03 PM
stugray   In my 71 Ghia, the ignition switch went out, I had...   Apr 18 2013, 05:13 PM
ericoneal   It worked! The starter turned and it sparked ...   Apr 18 2013, 07:11 PM
Rand   It worked! The starter turned and it sparked...   Apr 18 2013, 08:23 PM
kg6dxn   Just bypass that stupid relay. It's not suppos...   Apr 18 2013, 07:25 PM
ericoneal   Somewhere in Kentucky a 914 just roared back to li...   Apr 18 2013, 07:45 PM
Rand   Just bypass that stupid relay. It's not suppo...   Apr 18 2013, 08:18 PM
914itis   We love happy ending here ! Glad you did it...   Apr 18 2013, 08:01 PM
stugray   Glad it worked! The reason some add the relay...   Apr 18 2013, 09:08 PM
Rand   I know this is an area of debate, but eliminating ...   Apr 18 2013, 09:35 PM
Rand   asab   Apr 18 2013, 09:43 PM
Tom   ericoneal, Glad you found the reason why your ...   Apr 19 2013, 12:19 PM
ericoneal   Thanks, thats very helpful. I will keep an eye on...   Apr 19 2013, 12:49 PM
ThePaintedMan   ericoneal, Glad you found the reason why your...   Apr 19 2013, 12:56 PM
Tom   ThePaintedMan, It would be impractical to repla...   Apr 19 2013, 02:01 PM
18 User(s) are reading this topic (18 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 10:03 PM
