lsintampa |
Senior Member ![]() ![]() ![]() Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States ![]() |
75 2.0
Picture of pressure regulator (right side). 1. Correct position / orientation of the part? 2. The BLUE arrow is pointing to a wire with a spade connector on it. What does that attach to? Thanks, Len ![]() |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
That wire is the cht. It plugs into another wire coming from the harness with the injector wires. The regulator mounts on a bracket that is spot welded to the drivers engine tin, not the body
442nd914s |
Member ![]() ![]() Group: Members Posts: 139 Joined: 25-July 12 From: KC Suburb Member No.: 14,718 Region Association: None ![]() |
That wire is the cht. It plugs into another wire coming from the harness with the injector wires. The regulator mounts on a bracket that is spot welded to the drivers engine tin, not the body I stand corrected I was driving ,thinking and chewing at the same time. The fuel regulator is mounted on a L bracket part if the tin close to the body. My bad. That will teach me (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 12:06 AM |
