need advice restore or part out, what should i do |
dm65 |
Apr 22 2013, 08:15 PM
Newbie Group: Members Posts: 9 Joined: 22-April 13 From: ohio Member No.: 15,797 Region Association: None |
I have a 72 that's been in storage for over 30+ years and has rust to the point the doors don't close very well. I would like some opinions on whether I should restore it or part it out.
Wanted to restore for my first granddaughters 16 b-day but she doesn't seem to have interest in it at 11. These cars have never been flashy but I thought she would kinda like it.... Well anyways what would you do if this car was yours? What should I plan for cost? Injectors been missing for 30years so it may need a rebuild plus it has 99000 miles on it Interior is in nice conditions. No tears Also is anyone from Ohio Dave [attachmentid=382 404] Attached thumbnail(s) |
Dasnowman |
Apr 22 2013, 10:26 PM
You miss 100% of shots you don't take! Group: Members Posts: 265 Joined: 24-May 12 From: Tricities, B.C./ Lake Whatcom Member No.: 14,477 Region Association: Canada |
I have a 72 that's been in storage for over 30+ years and has rust to the point the doors don't close very well. I would like some opinions on whether I should restore it or part it out. Dave My teener had fairly straight body, very little rust, but once I started digging it got worse. The strait body ended up having up to 3" of filler, every body panel ended having a dent or damage somewhere. The little bit of surface rust here and there turned out to to be deeper then I expected. I think I lucked out as the engine has almost 150lbs of compression strait across but I still have to change all the dried out gaskets and fire it up so who knows. I would use this guide to better get an understanding of what you are dealing with! http://bowlsby.net/914/Classic/zTN_Gen_914CAF.pdf To be honest if the car had some rust and a good engine I would do it or if the body was good and the engine wasn't I would do it. But with both the body, engine and interior in ruff shape I don't think I would do it or it is to expensive to do. Think I have spent as much on tools as I have on the car so far. It's a whole different world from doing bolt of parts on newer cars for the last 20 years then doing a rustoration on a Teener. Every week it seems like I need more sand paper, wire wheels, zip cuts metal and tools to do one thing or another. car supplies Body panels 1000-3000 sandblasting 800-1500 paint and primer 600-1000 misc body stuff 200-300 body gaskets seals rubber 500-900 windshield $200-500 dash pad $100 carpet kits $150-300 seat foam, door cards and material $200-1000 long, chassis ,and suspension reinforcement $300-600 suspension, sway bars etc $1500 and up 5 lug swap $400-1000 wheels and tires 1000-3000 brake system $200-2000 engine 1500-18,000 tranny 200-3000 Consumables cleaners, fluids sand paper drill bits grinding and sanding disks zip cuts rotocut/spot weld cutter drill bit argon/co2 mix Shop Supplies Large Compressor welder 2-3 grinders sawza jigsaw drills two paint guns couple of drills rotisserie 2' jack stands x 4 or lift Car trailer or money for tow truck (sand blasting) air tools Lamps, heaters, fans heavy duty plastic for making paint booth in garage. tranny/engine jack engine stand |
Lo-Fi Version | Time is now: 26th June 2024 - 05:46 AM |
