Kaduku |
Member ![]() ![]() Group: Members Posts: 344 Joined: 1-January 13 From: SF Bay Area Member No.: 15,324 Region Association: None ![]() |
I was just about to pull the trigger on a new rear mirror replacement, but I just found out that you just can't hank the old one off without breaking the windshield.
Anyone successful in replacing their mirror without damaging your windshield? |
DBCooper |
14's in the 13's with ATTITUDE ![]() ![]() ![]() ![]() Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California ![]() |
I have that BMW mirror too. For the most part much better than the stock mirror, but if you're tall it sits just a bit too low in your field of vision. Just a wee bit. For me.
Madswede |
Flat Out Driver ![]() ![]() ![]() Group: Members Posts: 853 Joined: 13-September 06 From: Rio Rancho NM Member No.: 6,831 Region Association: Rocky Mountains ![]() |
I have that BMW mirror too. For the most part much better than the stock mirror, but if you're tall it sits just a bit too low in your field of vision. Just a wee bit. For me. This is my concern, as I'm on the tallish side. I'm going to order one just to try it out anyway. I suppose if I don't like it, I'll either re-sell it at a swap meet someday, or have someone cut a length of the arm off and re-weld it closer to the bracket or something. But then it might look a bit too funky. We'll see. |
andys |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None ![]() ![]() |
I have that BMW mirror too. For the most part much better than the stock mirror, but if you're tall it sits just a bit too low in your field of vision. Just a wee bit. For me. This is my concern, as I'm on the tallish side. I'm going to order one just to try it out anyway. I suppose if I don't like it, I'll either re-sell it at a swap meet someday, or have someone cut a length of the arm off and re-weld it closer to the bracket or something. But then it might look a bit too funky. We'll see. I installed the BMW mirror, and I find it is at its upward tilt adjustment limit which is not quite enough to see very far behind......I find myself ducking down just a bit to get a better view. I might try shimming the mounting base. I'm only 5'9", so I can imagine a taller driver would have an issue with this. Andys |
Lo-Fi Version | Time is now: 11th March 2025 - 01:15 AM |
