Chassis Stiffening - which kit? Cage?, Stiffening before paint, need help. |
corpselaurel |
Jul 4 2004, 10:12 AM
Member Group: Members Posts: 90 Joined: 15-April 04 From: usa Member No.: 1,931 |
I have been reading and searching. So far I have eliminated the boxed trailing arms.
I want to stiffen the car up before I paint. What 'kit(s)' should I install? I have read read that most of the pieces in the chassis stiffening kit are useless. Should I buy the kit and install the others? I have also read that engman's kit helps a lot. And I was also considering the Inner Rocker Panel Frame Stiffeners. I just don't know which combination I should install. Should I use all of them or do some cancel each other out (for lack of better wording). Post links to suppliers if you mention any. I am open to the idea of putting a cage in but it has to be in kit form. Does anyone sell one and would I still need any of the stiffening mentioned above with a cage? The car is not badly rusted except for the battery tray and underneath - completly gone. I will be repairing it. My plans for the car are daily driver with some autox. Next year I will swap in a more powerfull engine. Thanks for any help. |
corpselaurel |
Jul 4 2004, 11:33 AM
QUOTE(trekkor @ Jul 4 2004, 09:11 AM) My understanding is this: if you box stiffen the trailing arms , something else has to give. Like the trailing to chassis bushing mount points. Very bad and costly. Rips and tears. I landed a 3 wheel off the ground right turn in my Baja Bug of old that had a solid trans mount kit. Ripped the rear mount horn right in half. (IMG:style_emoticons/default/headbang.gif) Some areas of the car need flexabilty. I honestly dont know if the box kits help or not. (IMG:style_emoticons/default/confused24.gif) In my first post I stated that I have eliminated the trailing arm kit (for the exact reason you mentioned). I am trying to sort out everything else. I know that some of the pieces in the picture I posted above don't really do anything; I just don't know which ones. |
Lo-Fi Version | Time is now: 27th December 2024 - 06:17 PM |
