Mechanic in Missouri, 914 mechanic in Missouri |
taylordm@att.net |
Apr 16 2013, 08:20 AM
Newbie Group: Members Posts: 8 Joined: 5-May 09 From: Blue Springs Missouri Member No.: 10,333 Region Association: Upper MidWest |
Trying to get my 914 going, does anyone know a good mechanic near Blue Springs Missouri?
pcar916 |
Apr 25 2013, 11:10 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
Injectors gum up too and probably did if stored with gas in the lines. After that long I'd test each of them (briefly, they're rated for about 3v) with a six volt battery and make sure they buzz actively. Or you can take them to a commercial injector place that has an injector profiler. They can test them for pattern and flow and replace the rubbers for about $20 each.
Frankly, just to get them going I've done the battery thing and gently knocked the bases (not the actual fuel hole... that's metered) with a brass drift or wood to get them buzzing. That's not as good as getting them tested but got it going. Then officially tested later. Good luck |
Lo-Fi Version | Time is now: 26th June 2024 - 10:32 AM |
