Randal |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 ![]() |
If you are planning on using a steering quickner then keep your 13.75 or 14 inch steering wheel. I went down to a 12.25 inch and with the quickner it required more torque than the driver could manage in a 4.25 minute (65 corner) session at Medford.
I've found a 350mm (13.75") wheel with exactly the dish I want, so will be installing that shortly. The different size will require 12% more motion, but there will be less load which is my primary objective. Guessing the load will decrease 12%, but correct me if that is fuzzy math. I do like the quickner for a bunch of reasons. Here is a video from last Sunday at the UFO event. Tough little course to master in 4 runs. Ended up 4th overall after catching a cone on the last corner of my fastest run. 5 big time mistakes in the video run, but good to watch as you learn from your mistakes, some of which were just basic stuff. http://www.youtube.com/watch?v=_kLIDzBizEA Yea, and could you believe that weather. The Marina afternoons are typically Alaska weather, but not on Sunday. BTW Bill Charron won the event in his narrow bodied 914. (IMG:style_emoticons/default/flag.gif) |
ww914 |
914 Convert ![]() ![]() Group: Members Posts: 435 Joined: 29-September 11 From: Central Coast, CA Member No.: 13,621 Region Association: Central California ![]() |
If you are planning on using a steering quickner then keep your 13.75 or 14 inch steering wheel. I went down to a 12.25 inch and with the quickner it required more torque than the driver could manage in a 4.25 minute (65 corner) session at Medford. I've found a 350mm (13.75") wheel with exactly the dish I want, so will be installing that shortly. The different size will require 12% more motion, but there will be less load which is my primary objective. Guessing the load will decrease 12%, but correct me if that is fuzzy math. I do like the quickner for a bunch of reasons. Here is a video from last Sunday at the UFO event. Tough little course to master in 4 runs. Ended up 4th overall after catching a cone on the last corner of my fastest run. 5 big time mistakes in the video run, but good to watch as you learn from your mistakes, some of which were just basic stuff. http://www.youtube.com/watch?v=_kLIDzBizEA Yea, and could you believe that weather. The Marina afternoons are typically Alaska weather, but not on Sunday. BTW Bill Charron won the event in his narrow bodies 914. (IMG:style_emoticons/default/flag.gif) Nice run. Doesn't Bill win them all? |
Randal |
If you are planning on using a steering quickner then keep your 13.75 or 14 inch steering wheel. I went down to a 12.25 inch and with the quickner it required more torque than the driver could manage in a 4.25 minute (65 corner) session at Medford. I've found a 350mm (13.75") wheel with exactly the dish I want, so will be installing that shortly. The different size will require 12% more motion, but there will be less load which is my primary objective. Guessing the load will decrease 12%, but correct me if that is fuzzy math. I do like the quickner for a bunch of reasons. Here is a video from last Sunday at the UFO event. Tough little course to master in 4 runs. Ended up 4th overall after catching a cone on the last corner of my fastest run. 5 big time mistakes in the video run, but good to watch as you learn from your mistakes, some of which were just basic stuff. http://www.youtube.com/watch?v=_kLIDzBizEA Yea, and could you believe that weather. The Marina afternoons are typically Alaska weather, but not on Sunday. BTW Bill Charron won the event in his narrow bodies 914. (IMG:style_emoticons/default/flag.gif) Nice run. Doesn't Bill win them all? Bill did a great job down at the Marina last Sunday after a ton of work to get his car sorted. To be honest, my run was bad. Good thing is that the video helps you to figure out what you need to correct. |
Lo-Fi Version | Time is now: 26th June 2024 - 12:10 AM |
