 Forum Rules Classified Rules!
> 914-V8 Street car with Track Developed Chassis, 914 w/500HP 383, Big Brakes and great handling
stewteral
post Apr 29 2013, 10:01 PM
Old Member
Attached ImageAttached ImageAttached ImageI'm selling my 914-V8 to go play with a Formula Ford. I've spent the last 8 years developing and tuning the car and believe it is the ONLY 914V8 with a chassis developed for road courses.
For SALE: Porsche 914 Chevy V8 conversion car, $35k invested +, Price $16,500, certified funds -11.0 second Qtr Mile
-Built 383 Chevy SBC, output 500 HP, 4-bolt Mains
-Comp Cams Roller-cam, pushrods and hydraulic lifters
-Eagle 4130 crank
-Eagle forged rods
-10:1 Keith Black Hypereutectic pistons
-All parts balanced with harmonic balancer
-Stainless steel rockers
-Aluminum heads
-MSD Distributor & Ignition system
-Edelbrock aluminum intake manifold
-750 Holley 4-barrel Carb
-Custom aluminum valve covers
-180-degree headers
-Dual mufflers w/ Super-Trapps + Open pipe replacement for track days
-Canton Road Race baffled oil pan
-Canton 3Qt Accusump
-Dual oil coolers with fans
-All oil & fuel lines are Aeroquip
-Remote Meziere electric water pump – 55 GPM
-Camaro Aluminum radiator with dual fans
-Spare Chevy 4-bolt mains block
-Transmission: Porsche Turbo 930 4-spd trans with custom shift linkage
-Quaife Torsen Limited slip differential
-Turbo Porsche half-shafts and CV joints
-Custom flywheel with Porsche clutch
-Wilwood Hydraulic clutch master cylinder & peddle
-Wilwood Hydraulic clutch slave cylinder with Aeroquip flex-line
-Chassis: the ONLY race track developed suspension conversion car now running including spring rates, swabars, shocks, chassis squared adjustments and bump-steered. -Custom Dash: Porsche Tach, VDO Water temp, oil temp, oil pressure gages, Oil pressure & alternator warning LEDs. -Transmission oil temp gage
-Full rollcage
-Racing seats
-5-belt racing seat belts (driver)
-4-belt racing seat belts (passenger)
-Racing Engineer tuned spring rates
-Custom front and rear swaybars
-Koni adjustable Sport front shocks
-Custom built dual adjustable Koni rear shocks
-Spare rear springs
-Rear suspension bracing for track cornering loads
-Removable rear wing for track
-Rennspeed fiber glass fender flares, rocker panels and nose piece with splitter
-Custom fiberglass side cooling scoops to Engine Compartment
-Brakes: Wilwood 12” x 1.25” vented rotor, all wheels
-Wilwood 4-piston Aluminum Calipers, all wheels
-Aeroquip brake lines
-Wilwood Dual master cylinder w/ balance bar aluminum peddle
-Remote brake & clutch reservoirs in front trunk
-Street Wheels: 8” steel rims with TA Radials (street)
Track Wheels: 9-1/2” front Aluminum wheels w/ Fresh Goodyear racing slicks (track)
Track Wheels: 11” rear Aluminum Wheels w/ Fresh Goodyear racing slicks (track)
Documentation:
3” - 3-ring binder of Every part of the Chassis
3” - 3-ring binder of Every part of the engine.
3” - 3-ring binder of complete 930 trans shop manual 2” – 3-ring binder all about the Holley Carb w/ 2 shop manuals.
1” – 3-ring binder: Complete data support for all chassis and tire on-track settings.
Track Support: Seller will attend buyer’s initial track event to help in learning the car at The Streets of Willow Springs A custom towbar is also available.
To see the car in action here is the url for my last outing at Buttonwillow. It was interesting that I was following the yellow Serious NASCAR competitor with a 650HP Chevy. I was very satisfying to be able to pull him on the straights.
Now, of course, the excuses:
-First lap was slow and slippery in getting the slicks up to temp on that always greasy track. Note the tail stepping out in the 1st right-hand corner.
-This was my first time to run the track CW and I never felt I had the lines down, was not comfortable and couldn't get into a rhythm. Thus missing shifts and totally blowing my braking point at the end to the start straight. Ah shucks!
-For some dumb reason, I was black flagged on that last lap. It turned out to be corner worker error....not that unusual at these open track days. Still, the car ran great and was a kick-in-the-pants to drive.
http://www.youtube.com/watch?v=oeeWoJZm9C4
Terry, Camarillo, CA 805-482-0322
- Lo-Fi Version Time is now: 19th April 2025 - 03:49 PM
