Sloppy seconds... and thirds, '74 and later shifter related |
tomeric914 |
May 8 2013, 06:06 AM
One Lap of America in a 914! Group: Members Posts: 1,263 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
I searched but could not find... I have a '74 with side shift and ALL fairly new bushings. If I grab the linkage and move it from the firewall back, everything is nice and tight. The shifter though has roughly 4" of play side to side at the knob. As of a couple weeks ago, third has become difficult to find
There does not appear to be any support for the shift rod inside the tunnel other than the firewall bushing. Is this correct? Is there a better solution? (IMG:style_emoticons/default/confused24.gif) |
Dr Evil |
May 8 2013, 08:38 AM
Send me your transmission! Group: Members Posts: 23,030 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
There is only the firewall bushing. It sounds like there is too much slop in your shifter. You have removed all other from consideration with your report.
Your issue does not sound like a fore-aft one, it is a side to side one. So, shift forks are good in the gear box. Your side to side motion is not being communicated because of your sloppy shifter. Check the pinch bolt at the base of the shifter to the inner tunnel shift rod. |
Lo-Fi Version | Time is now: 24th September 2024 - 01:00 PM |
