thesey914 |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 ![]() ![]() |
I got a new pair of hubs because the aluminium was corroded badly on the old ones.
The new ones are identical in every dimension except they use larger grease caps. Does anyone have a part number for these so I can order some new caps? Unfortunately I threw out the old ones for comparison. These must come from a later 911 but before '89 as the bearings fit etc. Attached image(s) ![]() |
thesey914 |
Thanks for that info. I looked all over the hub but there doesn't seem to be a Part# there.
I found another part# on the 914 PET 901 341 065 04 FRONT WHEEL HUB 2 914-6 But I'm guessing this would be the same as the early hub I threw out. I wonder if there was another type after the number you quoted from '82-'89? |
Lo-Fi Version | Time is now: 26th June 2024 - 05:33 AM |
