Thursday, 17 April 2025
> Relief, Oiling system in a type 4
worn
post May 13 2013, 08:33 AM
If anyone has read my previous threads my two week vacation turned from driving to lying on the creeper under the new engine and transmission. Low oil pressure after warm up. I ordered a new Melling 30 mm pump and we shall see, but at the same time I looked into the pressure relief system - especially where it shunts oil away from the cooler because it is easier to see in the car.
What I found surprised me. First, looking at two different cases (72 1.7 and 76 2.0) I found that the piston seats on a shoulder in the bore that is at most a mm wide, and is not at all uniform in width across the piston face. OK, maybe it isn't supposed to seal.
Second I found that by the time you have opened the valve to shunt past the cooler, you are also dumping into the sump. That is there is a small overlap between the outlet to the oil gallery and the grooves cut in the bore leading to the sump exit.
Finally, the piston is simply loose in the bore. I can understand a fear of seizing, but there is no way that with my system oil isn't streaming into the sump, and it will stream faster as it thins - much faster.
I also spent a long time cruising the Samba - they ought to know whats up. What I found is a recurrent theme of new engines built in a variety of ways making low oil pressure. Many people were happy with what I ended up with - 10 psi at idle. On a new engine.
It is steel against untreated aluminum, so wear would be expected, but mine do not look worn - just poorly made. Maybe they are worn and I cannot tell. I got a face full of oil on one attempt at examination, so I may have missed things.
It seems an ideal situation for machining or sleeving during the rebuild, and I actually found a manufacturer of a sleeving kit with a ball bearing valve.
Thoughts ladies and gentlemen? (IMG:style_emoticons/default/idea.gif)
nathansnathan
post May 13 2013, 09:24 AM
I've experienced this same thing, low oil pressure on newly built motor. My conclusion after years of thinking searching, etc, the problem for me is wear in the bore of the oil pressure relief valve and oil pump bodies being too small on the newer type 1 pumps.
It was Adrian from headflow masters who really showed me how the relief valve wears. He had made a tool to check them, a screw driver welded to a relief piston. About half way up the bore you feel the groove it gets stuck on. What feels like a little lip with your finger, when the tool reaches that point, you can cock it out by way more than you think.
Different conditions can happen with wear there, too. If the seat isn't holding you will see low pressure at hot idle. Oil seeping by in the loose bore causes problems off idle. There are other ways it can fail, if it becomes cocked in the bore, it either won't open or it won't close depending on which end it gets stuck at.
I was pretty enthusiastic about Adrian's ball valve sleeve insert when he showed it to me. Reviews on shoptalkforums are not favorable, but it is just 1 guy that had a bad experience from what I can see. Adrain said the same, said he'd give me one for free if I let him install it. I was totally going to take him up on it, but didn't make it back down to Vista for like a year after, got a different case going in that time. I am still thinking about the ball valve.
Something that I couldn't figure is if it is knurled on the outside, because that one guy said it was, and that it never would come out, so it it gets screwed up on install the case is trash. It doesn't look knurled in the pic on Adrian's site, though. Still thinking about it...
worn
post May 13 2013, 09:38 AM
Yeah Nathan, I looked at that site too. I am way tempted.
It looks like the oil relief system is highly dependent on oil viscosity since there is no seat for the piston. The Welmeister kit seems to solve this by making longer pistons - that also mess with spring pressure. I suspect that the longer piston restricts escape flow more than stock.
I have to say I did not install the Melling pump as it came out of the box. I sanded down the clearances and then had to clean up a lot of sand casting in the flow passages.
worn   Relief   May 13 2013, 08:33 AM
reharvey   I've been following your posts about the oil p...   May 13 2013, 08:57 AM
worn   I've been following your posts about the oil ...   May 13 2013, 09:33 AM
worn   I've been following your posts about the oil ...   May 13 2013, 01:28 PM
reharvey   I've been following your posts about the oil...   May 14 2013, 03:28 PM
worn   [quote name='worn' post='1863422' date='May 13 20...   May 14 2013, 03:39 PM
Cap'n Krusty   How is a larger oil pump, which will definitely in...   May 13 2013, 09:20 AM
worn   How is a larger oil pump, which will definitely i...   May 14 2013, 12:56 PM
worn   Here is a drawing about what it looks like. Sorry...   May 13 2013, 09:22 AM
FourBlades   Keep in mind this is just a guess... The oil pres...   May 13 2013, 09:22 AM
nathansnathan   I've experienced this same thing, low oil pres...   May 13 2013, 09:24 AM
worn   Yeah Nathan, I looked at that site too. I am way...   May 13 2013, 09:38 AM
r_towle   Check the case main bearing seat size. Check the m...   May 14 2013, 02:33 PM
worn   Check the case main bearing seat size. Check the ...   May 14 2013, 02:49 PM
r_towle   [quote name='r_towle' post='1863940' date='May 14...   May 14 2013, 03:44 PM
worn   [quote name='r_towle' post='1863940' date='May 1...   May 14 2013, 09:16 PM
r_towle   [quote name='r_towle' post='1863972' date='May 14...   May 15 2013, 07:17 AM
worn   So, now what are you planning to do? Not sure I ...   May 15 2013, 12:08 PM
eyesright   FWIW I'm just now rereading the Haynes manual,...   May 14 2013, 02:33 PM
worn   FWIW I'm just now rereading the Haynes manual...   May 14 2013, 03:00 PM
yeahmag   Interesting for sure: http://www.headflowmasters....   May 14 2013, 03:14 PM
cary   Did you get a case yet? I have one that had a hol...   May 15 2013, 06:00 AM
r_towle   Please post some pics of what you are doing.   May 15 2013, 09:46 PM
worn   Please post some pics of what you are doing. OK...   May 16 2013, 08:44 AM
nathansnathan   aircooled.net used to rent out a 5/8" end mil...   May 16 2013, 09:05 AM
worn   aircooled.net used to rent out a 5/8" end mi...   May 16 2013, 09:24 AM
396   [quote name='r_towle' post='1864740' date='May 15...   May 20 2013, 10:16 AM
FourBlades   :popcorn: :popcorn: :popcorn: You have done a ...   May 16 2013, 01:21 PM
brant   This is what I described in your other thread it m...   May 16 2013, 01:59 PM
yeahmag   Just to refresh my memory, you are trying to get m...   May 16 2013, 02:08 PM
r_towle   Interesting. Might be worth getting a custom pisto...   May 16 2013, 04:52 PM
Jake Raby   All these rules and myths change when bearing clea...   May 16 2013, 09:31 PM
worn   All these rules and myths change when bearing cle...   May 17 2013, 09:10 PM
nathansnathan   What I think is interesting is we have numbers fo...   May 18 2013, 06:53 AM
worn   What I think is interesting is we have numbers f...   May 19 2013, 08:53 PM
worn   [quote name='nathansnathan' post='1865830' date='...   May 19 2013, 08:57 PM
cary   I learned another lesson as well. You cannot tune ...   May 19 2013, 10:29 PM
worn   [color=#330099][i]I learned another lesson as wel...   May 20 2013, 08:41 AM
yeahmag   So you went from 10PSI to 20PSI at idle with all t...   May 19 2013, 09:23 PM
worn   So you went from 10PSI to 20PSI at idle with all ...   May 20 2013, 08:45 AM
r_towle   So you went from 10PSI to 20PSI at idle with all...   May 25 2013, 11:49 AM
worn   [quote name='worn' post='1866719' date='May 20 20...   May 26 2013, 09:13 AM
r_towle   [quote name='worn' post='1866719' date='May 20 2...   May 26 2013, 02:30 PM
396   Sub as its very interesting read. After reading t...   May 19 2013, 10:09 PM
eyesright   My (home rebuild) engine is back in the car, oil l...   May 20 2013, 10:01 AM
eyesright   Warn I located the relief valve seat by looking u...   May 25 2013, 06:49 PM
76-914   Verify your "cheap gages" or you'll ...   May 26 2013, 07:53 AM
yeahmag   The VDO CHT is not temp compensated. You have to d...   May 26 2013, 09:44 AM
eyesright   worn I agree with yeahmag. My VDO CHT shows 350F....   May 26 2013, 03:19 PM
eyesright   PS Worn, oh yeah, one more thing. When you open th...   May 26 2013, 04:35 PM
- Lo-Fi Version Time is now: 17th April 2025 - 06:54 AM
