> JOE's 2013 Hershey Emergency Thread, 5th ANNUAL
jsayre914
post Mar 15 2013, 02:13 PM
Speed Up !!!
And so it begins.
I have been driving the car every day since the 2056 went in. It goes from Baltimore To York PA multiple times a day. I drive kinda quick and really enjoy the power. Of course there have been hiccups along the way, trying to slow me down. IE clutch pedal pin sheering off, exhaust falling apart, SNOW (IMG:style_emoticons/default/biggrin.gif) , and of course the usual D-Jet Gremlins. Until today.
I adjusted all the valves last week to spec "0" lash, timing is on point. Car is running awesome, comming down 83 when I get to the end of the expressway. Car starts running on 3 (IMG:style_emoticons/default/WTF.gif) then I see the white smoke comming from seemingly under the car. (IMG:style_emoticons/default/WTF.gif) (IMG:style_emoticons/default/WTF.gif)
Pull over and pop the lid, there is a solid quart of oil dripping from the top of the lid, spatter on the side of the bay (driverside) pool of oil on the engine shelf (driver side) and a pool of oil in the middle near the filler.
(IMG:style_emoticons/default/hissyfit.gif)
I take it step by step, holding my chin up.
Wipe all oil away, remove breather box and check all vacume connections. AHHA! The connection from the passenger side port came off of the three way connector going to the air box. BUT WHY ! and why so much oil! and Why is number one no longer firing.
Closer inspection of #1 reveals the fuel pressure regulator in its position is soaked and dripping with oil from the bottom, but clean and dry on the top. Pull the plug wire and the plug is also dripping with oil from the top white area.
O.K. relax breathe
Go to pull the plug to have a peak.
NOPE
Will turn a 1/4 turn and then i can feel the extension start to flex. It is permantly attached to the head. I tried it all. S T U C K
I have a great running 3 cylinder porsche, number one is dead. I have no idea what happend, what I do know is that i have verified spark right down to the plug by putting another plug inline to ground. Verified fuel (switching injectors) and I cant verify compression with a plug in the hole (IMG:style_emoticons/default/headbang.gif)
My Hershey Emergency is officially under way.
(IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif)
ChrisFoley
post May 15 2013, 10:58 AM
I am Tangerine Racing
The exhaust is ready to ship to Tony.
jsayre914
post May 15 2013, 01:07 PM
Speed Up !!!
QUOTE(Racer Chris @ May 15 2013, 12:58 PM) *
Such a nice guy (IMG:style_emoticons/default/wub.gif)
jsayre914   JOE's 2013 Hershey Emergency Thread   Mar 15 2013, 02:13 PM
jsayre914   A Quick History of Hershey and Joseph for the Newb...   Mar 15 2013, 02:28 PM
Dr Evil   Might as well take it back to Tony :rolleyes:   Mar 15 2013, 06:23 PM
struckn   Might as well take it back to Tony :rolleyes: ...   Mar 15 2013, 06:35 PM
Vacca Rabite   Okay... You can turn the plug 1/4 turns. Is ther...   Mar 15 2013, 07:29 PM
Elliot Cannon   Worse case is, a valve head broke off, banged repe...   Mar 15 2013, 07:49 PM
Vacca Rabite   Just got off the phone with Joe. The car is runnin...   Mar 15 2013, 08:02 PM
r_towle   But he just did a valve adjustment Zach Loosen...   Mar 16 2013, 10:49 AM
Vacca Rabite   But he just did a valve adjustment Zach Loose...   Mar 16 2013, 11:38 AM
Elliot Cannon   At least it's running. :D He said he adjuste...   Mar 16 2013, 10:44 AM
Woody   :agree:   Mar 16 2013, 11:58 AM
saigon71   Brutal news Joe and the timing for Hershey is impe...   Mar 16 2013, 12:37 PM
rmital   I don't understand the zero lash valve adjust...   Mar 16 2013, 12:49 PM
stugray   If you use the Chromoly pushrods, then the lash is...   Mar 16 2013, 12:50 PM
Vacca Rabite   Using chromolly steel pushrods allows you to set l...   Mar 16 2013, 12:53 PM
jsayre914   Plug is stuck permanently <_< but its stil...   Mar 20 2013, 04:15 PM
Dave_Darling   The intake adjuster is now tight against the rock...   Mar 20 2013, 10:35 PM
struckn   The intake adjuster is now tight against the roc...   Mar 21 2013, 06:32 PM
Vacca Rabite   Joe, please have Tony look at it. That engine sho...   Mar 20 2013, 05:56 PM
jsayre914   I did not drive it today :poke: Will drop it by...   Mar 21 2013, 01:02 PM
Dr Evil   You feeling Ok, Joe? You never take advise that yo...   Mar 21 2013, 02:36 PM
Vacca Rabite   If you bring it over this weekend we could hookup ...   Mar 21 2013, 04:41 PM
r_towle   It runs fine again, most likely it was an over tig...   Mar 21 2013, 07:35 PM
jsayre914   <_< The seat was hammerd into the head........   Apr 9 2013, 07:40 AM
Vacca Rabite   <_< The seat was hammerd into the head.......   Apr 9 2013, 06:23 PM
saigon71   <_< The seat was hammerd into the head.......   Apr 9 2013, 08:27 PM
jsayre914   :sad2:   Apr 9 2013, 07:41 AM
dirk9141973   :blink: what does valve hammer in head look like ?   Apr 9 2013, 06:39 PM
914_teener   Geez, I am wondering after reading the past thread...   Apr 9 2013, 10:25 PM
jsayre914   Geez, I am wondering after reading the past threa...   May 15 2013, 01:08 PM
jsayre914   It has now been 52 days 2 hours and 17 min since m...   May 15 2013, 10:22 AM
Racer Chris   The exhaust is ready to ship to Tony.   May 15 2013, 10:58 AM
jsayre914   The exhaust is ready to ship to Tony. Such a ni...   May 15 2013, 01:07 PM
rgolia   I know how you feel Joe...I am waiting for my whee...   May 15 2013, 02:15 PM
jsayre914   I know how you feel Joe...I am waiting for my whe...   May 15 2013, 02:34 PM
Vacca Rabite   That's good news. Did he dyno the engine? I...   May 15 2013, 03:06 PM
jsayre914   That's good news. Did he dyno the engine? I...   May 15 2013, 04:39 PM
struckn   Hey Joe, like you told me last year, "the wai...   May 15 2013, 07:16 PM
jsayre914   66 days 8hrs 7 min :headbang: :headbang: ...   May 29 2013, 03:51 PM
jsayre914   still waiting......   May 29 2013, 03:52 PM
struckn   still waiting...... :unsure: :unsure: :ide...   May 29 2013, 08:38 PM
jsayre914   UPDATE: 92 Days and counting since I drove a 914...   Jun 24 2013, 04:26 PM
76-914   Have you choked anyone, yet?   Jun 24 2013, 05:30 PM
jsayre914   ........108.......... ........... :confused...   Jul 10 2013, 04:38 PM
Marv's3.6six   [quote name='jsayre914' date='Jul 10 2...   Jul 12 2013, 09:25 AM
Vacca Rabite   Any word from Tony?   Jul 12 2013, 09:54 AM
Racer Chris   You need a spare engine Joe.   Jul 12 2013, 10:54 AM
jsayre914   You need a spare engine Joe. I gave it to Tony ...   Jul 12 2013, 12:40 PM
struckn   You need a spare engine Joe. I gave it to Tony ...   Jul 12 2013, 01:20 PM
rgolia   Again...if it makes you feel any better I am still...   Jul 12 2013, 01:07 PM
jsayre914   Just talked with Tony......... Engine was finish...   Jul 29 2013, 11:11 AM
flipb   Sorry, Joe. I dropped off my 914 a while back for...   Jul 29 2013, 11:52 AM
Vacca Rabite   What kind of numbers did you get from the dyno? It...   Jul 29 2013, 12:47 PM
Dr Evil   Man, you have some shit luck.   Jul 29 2013, 01:55 PM
jsayre914   Update: Engine is good to go. :Qarl: :Qarl: :...   Jul 31 2013, 02:31 PM
Java2570   That is excellent news!! :beer2:   Jul 31 2013, 02:55 PM
Vacca Rabite   Wow! 130 with DJet?! WOW! That is some...   Jul 31 2013, 03:47 PM
Dr Evil   I am guessing 130 at the flywheel. How much is los...   Jul 31 2013, 04:04 PM
balljoint   I am guessing 130 at the flywheel. How much is lo...   Jul 31 2013, 04:32 PM
jsayre914   I am guessing 130 at the flywheel. How much is lo...   Jul 31 2013, 05:23 PM
Vacca Rabite   Yeah, but still. 130 at the flywheel is what I am ...   Jul 31 2013, 05:40 PM
Racer Chris   The drivetrain losses are more like 15%. 130 x .85...   Jul 31 2013, 06:45 PM
jsayre914   The drivetrain losses are more like 15%. 130 x .8...   Aug 1 2013, 12:53 PM
struckn   Great News Joe, looks like Hershey 2014 finally fo...   Jul 31 2013, 08:35 PM
r_towle   Great News Joe, looks like Hershey 2014 finally f...   Aug 1 2013, 05:12 AM
Vacca Rabite   Great News Joe, looks like Hershey 2014 finally ...   Aug 3 2013, 12:37 PM
Porschef   Good news Joe. No reason why you won't be at C...   Aug 1 2013, 04:23 AM
Dr Evil   When is ECC? You mean ECC 2013?   Aug 3 2013, 12:56 PM
type47   When is ECC 2013? http://www.914world.com/bbs2/i...   Aug 3 2013, 02:51 PM
Vacca Rabite   October. I am already bugging/bribing Bob to come...   Aug 3 2013, 01:08 PM
jsayre914   TOUCHDOWN !!! picked my car up yeste...   Aug 7 2013, 11:50 AM
19 User(s) are reading this topic (19 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd December 2024 - 12:22 PM
