> Under-body AND through-body sway bar?, Good idea? Bad idea? impossible?
bondo
post Jul 6 2004, 01:29 PM
My new 914 has front and rear sway bars.. the Carrera suspension I plan to put on it has a built in sway bar. Can I use both to have an effectively larger sway bar? Also, should I use the rear sway bar or take it off? (I've heard they don't do much for you)
Mueller
post Jul 6 2004, 01:36 PM
914 Freak!
i see no reason why it wouldn't work, is the thru-the-body swaybar adjustable?
that is what you'd want for sure since the under-the-body bar is not adjustable
if you have to buy anything new for this proposed combo, you might as well pony up and buy a bigger new thru-the-body swaybar..Tarett or SmartRacing
- Lo-Fi Version Time is now: 28th December 2024 - 01:02 AM
