Sloppy seconds... and thirds, '74 and later shifter related |
tomeric914 |
May 8 2013, 06:06 AM
One Lap of America in a 914! Group: Members Posts: 1,263 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
I searched but could not find... I have a '74 with side shift and ALL fairly new bushings. If I grab the linkage and move it from the firewall back, everything is nice and tight. The shifter though has roughly 4" of play side to side at the knob. As of a couple weeks ago, third has become difficult to find
There does not appear to be any support for the shift rod inside the tunnel other than the firewall bushing. Is this correct? Is there a better solution? (IMG:style_emoticons/default/confused24.gif) |
tomeric914 |
May 16 2013, 09:31 PM
Don't use the aluminum part of the joint to press against. Best to place a socket large enough to support the old (and later new) bushing and press out the pin. As I recall, the pin is slightly tapered toward the center. You would need to press it in an out A LOT to wear it.
Lo-Fi Version | Time is now: 24th September 2024 - 01:06 PM |
