2.0 Rebuild Advice Needed, 2056 or 2270? |
john_g |
May 15 2013, 07:29 PM
Member Group: Members Posts: 110 Joined: 1-November 12 From: british columbia Member No.: 15,100 Region Association: Canada |
I'm getting ready to rebuild my 2.0 and am considering going to either 2056, or maybe even up to 2270. What are the downsides or problems associated with going 2270, if any?
Jake Raby |
May 16 2013, 09:25 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Its been over a decade since we had any thermal control issues.
Pretty much the 2270 is the only engine combination that we work with now, we won't even build a single 2056 this entire year since the schedule already stretches into 2014 I know this.. Again, if you don't have the required coin for proper heads, then stick with the 2056, because you'll just be spinning your wheels. Smarter beats larger every single time. |
john_g |
May 17 2013, 09:36 AM
Its been over a decade since we had any thermal control issues. Pretty much the 2270 is the only engine combination that we work with now, we won't even build a single 2056 this entire year since the schedule already stretches into 2014 I know this.. Again, if you don't have the required coin for proper heads, then stick with the 2056, because you'll just be spinning your wheels. Smarter beats larger every single time. Thanks, Jake. So, you don't use an external oil cooler in your 2270's? |
Jake Raby |
May 17 2013, 02:36 PM
Its been over a decade since we had any thermal control issues. Pretty much the 2270 is the only engine combination that we work with now, we won't even build a single 2056 this entire year since the schedule already stretches into 2014 I know this.. Again, if you don't have the required coin for proper heads, then stick with the 2056, because you'll just be spinning your wheels. Smarter beats larger every single time. Thanks, Jake. So, you don't use an external oil cooler in your 2270's? Totally dependent upon application and climate This post has been edited by Jake Raby: May 17 2013, 02:52 PM |
john_g |
May 17 2013, 05:30 PM
Its been over a decade since we had any thermal control issues. Pretty much the 2270 is the only engine combination that we work with now, we won't even build a single 2056 this entire year since the schedule already stretches into 2014 I know this.. Again, if you don't have the required coin for proper heads, then stick with the 2056, because you'll just be spinning your wheels. Smarter beats larger every single time. Thanks, Jake. So, you don't use an external oil cooler in your 2270's? Totally dependent upon application and climate Given those two factors, I should be good w/o one, since I live in western Canada and this is strictly for street use. Again, thanks for the advice. (IMG:style_emoticons/default/aktion035.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 09:56 PM |
