worn |
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,466 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest ![]() ![]() |
If anyone has read my previous threads my two week vacation turned from driving to lying on the creeper under the new engine and transmission. Low oil pressure after warm up. I ordered a new Melling 30 mm pump and we shall see, but at the same time I looked into the pressure relief system - especially where it shunts oil away from the cooler because it is easier to see in the car.
What I found surprised me. First, looking at two different cases (72 1.7 and 76 2.0) I found that the piston seats on a shoulder in the bore that is at most a mm wide, and is not at all uniform in width across the piston face. OK, maybe it isn't supposed to seal. Second I found that by the time you have opened the valve to shunt past the cooler, you are also dumping into the sump. That is there is a small overlap between the outlet to the oil gallery and the grooves cut in the bore leading to the sump exit. Finally, the piston is simply loose in the bore. I can understand a fear of seizing, but there is no way that with my system oil isn't streaming into the sump, and it will stream faster as it thins - much faster. I also spent a long time cruising the Samba - they ought to know whats up. What I found is a recurrent theme of new engines built in a variety of ways making low oil pressure. Many people were happy with what I ended up with - 10 psi at idle. On a new engine. It is steel against untreated aluminum, so wear would be expected, but mine do not look worn - just poorly made. Maybe they are worn and I cannot tell. I got a face full of oil on one attempt at examination, so I may have missed things. It seems an ideal situation for machining or sleeving during the rebuild, and I actually found a manufacturer of a sleeving kit with a ball bearing valve. Thoughts ladies and gentlemen? (IMG:style_emoticons/default/idea.gif) |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
All these rules and myths change when bearing clearances are altered. I prefer to move a higher volume of oil through the engine and to do that requires a higher volume oil pump and altered internal clearances.
There are no rules, if there were I wouldn't enjoy it so damn much. |
worn |
All these rules and myths change when bearing clearances are altered. I prefer to move a higher volume of oil through the engine and to do that requires a higher volume oil pump and altered internal clearances. There are no rules, if there were I wouldn't enjoy it so damn much. Replying to Jake and Yeah. I was worried that 10-15 psi at hot idle was too low for a new engine. That is what started it. I will find out tomorrow and if it worked will start tuning my mps - the horror. What I think is interesting is we have numbers for bearing clearances, suggested tolerances for oil pump lapping and lash, but nada, zipperino, nothing when it comes to the system that is designed to actually control oil pressure. I had to hunt for diameters and spring constants and never found them. So, I will post cylinder head and oil temps, rpms and hopefully oil pressure. And God willing I won't pop the cooler instead. This ruined my vacation and added stress when really, I wanted seat time with the world flying by my narp. (IMG:style_emoticons/default/driving.gif) |
nathansnathan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,052 Joined: 31-May 10 From: Laguna Beach, CA Member No.: 11,782 Region Association: None ![]() |
What I think is interesting is we have numbers for bearing clearances, suggested tolerances for oil pump lapping and lash, but nada, zipperino, nothing when it comes to the system that is designed to actually control oil pressure. I had to hunt for diameters and spring constants and never found them. The specs are as follows, from the Porsche 914 Technical Specs book Spring for oil pressure relief valve length loaded: 39mm, on installation new 6.8-8.8 kg (15-19 3/8 lbs lbs) Oil pressure switch opens at 6.6-8.8kg (2.1 -6 psi) I don't see bore sizes anywhere, possibly 16mm bore? |
worn |
What I think is interesting is we have numbers for bearing clearances, suggested tolerances for oil pump lapping and lash, but nada, zipperino, nothing when it comes to the system that is designed to actually control oil pressure. I had to hunt for diameters and spring constants and never found them. The specs are as follows, from the Porsche 914 Technical Specs book Spring for oil pressure relief valve length loaded: 39mm, on installation new 6.8-8.8 kg (15-19 3/8 lbs lbs) Oil pressure switch opens at 6.6-8.8kg (2.1 -6 psi) I don't see bore sizes anywhere, possibly 16mm bore? And of course springs mean nothing without the area of oil pressure they push against. But I digress. Back on the road to full temp on a warm day. I made about 20 psi at idle with 10w30 oil. Not the Oil I would normally run, but I was worried about hitting the oil pressure trifecta. Bottom line, I see no reason to tear apart the motor now, I have the case I just pulled out and it shan't be wasted. A swap may be in the future. I think the lesson to be learned is to check everything including bearing clearances, and not forgetting oil relief. I learned another lesson as well. You cannot tune the factory fi without both an inductance meter and an a/f gauge. You may shy away from pbanders warning that all inductance meters aren't alike, but I scored one from ebay for 30-40 dollars that works like a charm. As with Ohms or Farads, Henry's are standards. A little change makes a world of difference and while the result are obvious on the air fuel gauge, it isn't from the seat. My goodness, what a sweet engine. |
worn |
What I think is interesting is we have numbers for bearing clearances, suggested tolerances for oil pump lapping and lash, but nada, zipperino, nothing when it comes to the system that is designed to actually control oil pressure. I had to hunt for diameters and spring constants and never found them. The specs are as follows, from the Porsche 914 Technical Specs book Spring for oil pressure relief valve length loaded: 39mm, on installation new 6.8-8.8 kg (15-19 3/8 lbs lbs) Oil pressure switch opens at 6.6-8.8kg (2.1 -6 psi) I don't see bore sizes anywhere, possibly 16mm bore? And of course springs mean nothing without the area of oil pressure they push against. But I digress. Back on the road to full temp on a warm day. I made about 20 psi at idle with 10w30 oil. Not the Oil I would normally run, but I was worried about hitting the oil pressure trifecta. Bottom line, I see no reason to tear apart the motor now, I have the case I just pulled out and it shan't be wasted. A swap may be in the future. I think the lesson to be learned is to check everything including bearing clearances, and not forgetting oil relief. I learned another lesson as well. You cannot tune the factory fi without both an inductance meter and an a/f gauge. You may shy away from pbanders warning that all inductance meters aren't alike, but I scored one from ebay for 30-40 dollars that works like a charm. As with Ohms or Farads, Henry's are standards. A little change makes a world of difference and while the result are obvious on the air fuel gauge, it isn't from the seat. My goodness, what a sweet engine. And I should add. Buy the DVD if you must, but the tranny rebuild is just what the Dr (me) ordered. Being able to count on shifting is so cool. You either know what I mean, or things are working the way they should. (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 11th April 2025 - 08:01 PM |
