jeff boucher |
Newbie ![]() Group: Members Posts: 3 Joined: 20-May 13 From: salem mass Member No.: 15,894 Region Association: None ![]() |
checked for power none took pump out connected to 12 volts nothing removed top and tryed power again and 5 steel barrels went flying 1and1/2 hours later found them all cleaned all parts put back and pump runs good but have no power at connection tinking its relay how do i check new to this thanks
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Guessing at a D-jet equipped car. You'll only have power for about 1.5 seconds after you turn the key on. The power returns after the car cranks and runs. Replace the FI and fuel pump relays with the 2 for the headlight motors. If that solves the problem, you're good. If not, look at PB Anders excellent D-jet website:
http://members.rennlist.com/pbanders/djetparts.htm More help than you may ever need, and everything there is verified to be correct over years of use. If you have a 1.8 with L-jet, we need to further explore the problems. The Cap'n |
Lo-Fi Version | Time is now: 25th June 2024 - 12:58 AM |
