jeff boucher |
Newbie ![]() Group: Members Posts: 3 Joined: 20-May 13 From: salem mass Member No.: 15,894 Region Association: None ![]() |
checked for power none took pump out connected to 12 volts nothing removed top and tryed power again and 5 steel barrels went flying 1and1/2 hours later found them all cleaned all parts put back and pump runs good but have no power at connection tinking its relay how do i check new to this thanks
Brian_Boss |
Member ![]() ![]() Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 ![]() |
Don't mean to insult you but did you check the fuse?
In addition to the fuel pump drawing too much current, if the AAR wire shorts to ground, it blows the fuse. |
Lo-Fi Version | Time is now: 25th June 2024 - 12:54 AM |
