> 901 gears and shafts, Anyone know what alloy?
bondo
post Jul 6 2004, 01:57 PM
I found someone at Cal Poly willing to help me with annealing and rehardening 901 internals so I can machine them. He said it would be helpful to know what alloy the steel is. He also asked if they were case hardened.
RAR
post Jul 7 2004, 11:27 AM
QUOTE(bondo @ Jul 7 2004, 07:12 AM)
Two second gears? Nope. I want a taller ratio for 5th, for a v8 conversion. I want to reverse the positions of the second gear gears and put them in place of 5th. I am trying to sacrifice a mainshaft to get the gear off. The remachined gear will go on a stock mainshaft. I don't think it's case hardened, I did some grinding on the pinion shaft I plan to use as a broach, and it's hard well past a few thousanths deep.
Ahhh, I see.
I figured case hardening to be about 1mm. That's about 40 thou, "few" is subjective. If Cal Poly has a machine shop, they may very well have a Rockwell tester. As stated a hardness test doesn't indicate the type of material, but it will give you an idea of how hard the gears need to be.
- Lo-Fi Version Time is now: 28th December 2024 - 01:54 AM
