larss |
Member ![]() ![]() Group: Members Posts: 428 Joined: 10-September 09 From: Sweden Member No.: 10,787 Region Association: Scandinavia ![]() |
After replacing bushings at my 914/4 -72 tailshift and re-adjusting the linkage I have a almost perfect shift in any gears and at any speed.
The only problem (right now) is that when starting cold in the morning (say 50-55F) there is a grind when shifting into 2nd. This is during the first minutes only, after that shifting into 2nd is like a dream again. The grind is wery noisy, almost as I try to get in reverse. I run Swepco 201. Any ideas? /Lars S |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Remove the shifter assembly and carefully inspect the lockout plate and the condition of the lever. Odds are both are worn. Plates are still available, I believe. (Part number for the plate is 901 724 017 00.) If not, or if you're willing to put forth A little effort and can weld, you can repair the plate and the shaft by hardfacing both and grinding/filing them back to where they should be. A MIG welder should do the job right.
The Cap'n |
larss |
Remove the shifter assembly and carefully inspect the lockout plate and the condition of the lever. Odds are both are worn. Plates are still available, I believe. (Part number for the plate is 901 724 017 00.) If not, or if you're willing to put forth A little effort and can weld, you can repair the plate and the shaft by hardfacing both and grinding/filing them back to where they should be. A MIG welder should do the job right. The Cap'n Thanks Cap'n! Before I started to look at the plate I made another check on the rod joint in the tunnel, I could then see (from close photos before/after) that instead of just twisting the rear rod one spline I had twisted it 3 splines, Sorry for that misinformation! Twisted the rod back 2 splines and tested: it shifts like a dream, no more grinding into 2nd and no more hard shifting out of 1st, all gears perfect. My only remaining question is: should I keep the good brand (ELF) GL5 80W/90 oil which I just changed to in looking for shifting improvments, or should I go back to the Swepco 201 which i saved? /Lars S |
Lo-Fi Version | Time is now: 26th June 2024 - 05:14 AM |
