> offset versus scrub radius
r_towle
post May 23 2013, 12:41 PM
Custom Member
Does it make a difference what the offset is on a wheel with regards to scrub radius?
It does not seem that it would, given the stock suspension, no custom struts etc.
Aside from that, what is the reason (aside from cost and availability) for using large spacers versus getting wheels that mount up with no spacer, yet are wide for flared cars?
rich
zig-n-zag
post May 24 2013, 02:03 PM
In an effort to eliminate front spacers, I found some late 911 turbo hubs.
They are 22mm wider over standard 911 hubs.
I don't know what effect they will have on the scrub radius.
post May 24 2013, 02:52 PM
Resident German
QUOTE(zig-n-zag @ May 24 2013, 01:03 PM) *
Neither spacers nor wider hubs or even backspace or wheel offsets are really relevant.
They all can affect the scrub radius, but the real answer to take away from all of this is:
Whatever you use, make sure your front wheels are as close to the strut as possible without rubbing on the strut or fender.
r_towle   offset versus scrub radius   May 23 2013, 12:41 PM
Matt Romanowski   Does it make a difference what the offset is on a...   May 23 2013, 03:01 PM
r_towle   Still confused, sorry. Just wondering if a wheel b...   May 23 2013, 08:26 PM
J P Stein   The following sketch does not represent all of the...   May 24 2013, 07:32 AM
Randal   The following sketch does not represent all of th...   May 24 2013, 04:53 PM
Matt Romanowski   The following sketch does not represent all of th...   May 25 2013, 09:55 AM
J P Stein   That diagram has nothing to do with camber. The g...   May 26 2013, 07:09 AM
Matt Romanowski   [quote name='Matt Romanowski' post='1869513' date...   May 26 2013, 07:40 AM
r_towle   Seems to me, given my original quest, that anythin...   May 24 2013, 08:27 AM
J P Stein   One is limited by the 914s front suspension. The m...   May 24 2013, 09:14 AM
andys   And increased scrub radius creates a cross jacking...   May 24 2013, 09:25 AM
zig-n-zag   In an effort to eliminate front spacers, I found s...   May 24 2013, 02:03 PM
SirAndy   In an effort to eliminate front spacers, I found s...   May 24 2013, 02:52 PM
tomeric914   Whatever you use, make sure your front wheels are...   Jun 22 2013, 08:04 PM
r_towle   Lots of great knowledge. Seems that my initial que...   May 24 2013, 03:55 PM
J P Stein   For anyone that has the chance........ Take a look...   May 25 2013, 05:47 AM
Randal   For anyone that has the chance........ Take a loo...   May 25 2013, 12:04 PM
J P Stein   Going to dial in a bit more front bar for the Cas...   May 26 2013, 07:20 AM
Randal   Going to dial in a bit more front bar for the Ca...   May 27 2013, 03:47 PM
andys   Slight hijack, but since we're talking scrub r...   May 27 2013, 02:10 PM
byndbad914   ...will taking out that scrub radius and going to ...   May 31 2013, 04:55 PM
stownsen914   I believe all car suspensions have some scrub radi...   Jun 15 2013, 04:09 AM
andys   You know, I have to appologize for throwing out so...   May 27 2013, 04:06 PM
J P Stein   Let's keep it simple. A certain amount of Scru...   Jun 23 2013, 07:19 AM
9 User(s) are reading this topic (9 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 2nd December 2024 - 04:40 AM
