r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,599 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Does it make a difference what the offset is on a wheel with regards to scrub radius?
It does not seem that it would, given the stock suspension, no custom struts etc. Aside from that, what is the reason (aside from cost and availability) for using large spacers versus getting wheels that mount up with no spacer, yet are wide for flared cars? rich |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
For anyone that has the chance........
Take a look at Frank Stagrano's (sp?) SCCA CP class dominating Mustang. Note the front wheels......now look at those that are .....er....not dominating. I had a brief conversation with him. IIRC, he said that was the 4th or 5th front end set-up on his car. One thinks someone else would notice....unless they're too busy building V-8 horsepower. (IMG:style_emoticons/default/confused24.gif) Randal: You went a bit over my front tire widths and it sounds like it worked. If so and you over cook it, you should hit the wall backwards. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 27th June 2024 - 07:07 PM |
