Changing Fan Belt in a /6 with A/C, Can't be hard, right? |
iiibdsiil |
Jul 6 2004, 10:12 PM
Needs Door Locks Group: Members Posts: 605 Joined: 19-November 03 From: Tampa / Boca Raton, FL Member No.: 1,362 |
My fan belt is pretty loose on the 3.2. I figure for the extra $15, just replace it. Anyways, I have seen 911 belts done, kinda. I know there are the shims which you have to adjust accordingly.
So, my problems comes with the A/C and the shims. How does this work? Does each one have to be shimmed seperately, A/C and fan belt, or what? Also, there is a special wrench for this too, correct? Since you have to take the center bolt out and not let the motor turn over? Am I going to run into any problems with the fan being kinda close to the firewall? I know most of the /6 conversions, at least on the race cars, have a cut out in the firewall to make life easier. I a willing to do this at some point, but the belt is starting to scare me now. Anything else I need to know? Thanks in advance. - Brett Smith |
joea9146 |
Jul 7 2004, 01:22 PM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
The tension on the Airconditiong belt is adjusted by sliding the compressor from left to right... no shims required. The fan belt is where the shims are located. there should be a total of 6 shims all are required for the assembly to work properly. The shims go behind the pulley the more shims you put behind the pulley the losser the belt will fit. The shims push the pulley outward allowing the belt to drop down. No shims pushes the pulley in putting pressure on the belt pushing it upward. The extra shims must go between the Cone piece that is under the big nut.
Yes there is a special tool to hold the pulley while you lossen or tighten the nut. I have a center hole which allows me to Zip the fan nut off with the impact gun. No holding required. Putting it on is a little tricky since I do not recommend the Impact gun for installation. With out a center hole this is a very difficult job. |
Lo-Fi Version | Time is now: 27th December 2024 - 11:14 PM |
