Jug size |
Jug size |
ruddyboys |
Jul 8 2004, 01:16 PM
Hummel eigentümer Group: Members Posts: 595 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
Is the outside diameter of a bigbore 96mm jug the same as the stock diameter?
74914LE |
Jul 8 2004, 01:53 PM
Member Group: Members Posts: 136 Joined: 6-April 04 From: Fort Worth, TX Member No.: 1,895 |
You will need to have the heads milled out to fit the 96mm jugs. The case should work,
but it is a tight fit. I have done this twice. Both times I put the 1.8Ltr. Big Bore kit on a 1.7Ltr. case. With this set up, you get the thicker wall size on the cylinders, but the heads must be enlarged. 74914LE |
Lo-Fi Version | Time is now: 28th December 2024 - 12:18 AM |
