Chris H. |
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,054 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest ![]() ![]() |
Finally starting the thread. First, I never would have done this if it weren't for several of you helping me out, especially Ian at:
Cold Water Conversions Ian tolerated dozens of questions from me as I decided which way to go. Thanks again! Here is the candidate (or victim, depending on what side of the fence you are on): ![]() A 1975 1.8L with California Emissions...I've had it for almost 11 years. During that time I have logged about 2800 miles on it. I decided to swap it out for a modern drive train so my daughter could drive it so I started looking for a 2.2L Subie and a 2WD auto trans. This setup CAN be made to work with a custom hanger, but it's not a very exciting trans. Think early '90's Camry or Corolla acceleration. I'm sure it could be re-geared but an Audi trans would probably be a much better option. Then I found and SVX for cheap and changed directions entirely. Looks like my kid will be learning to drive a 5 speed Subie! So far I have: ![]() Strong running SVX engine ![]() 2006 WRX trans purchased from NASIOC ![]() If you don't feel like chasing this stuff down Ian will source it for you. Next up I'll post the highlights of the SVX strip-down and note some of the pitfalls, valuable parts, and stuff to be careful not to break! Any feedback, comments, questions, concerns are welcome. I want to do it right. |
nsyr |
Because I Can ![]() ![]() Group: Members Posts: 314 Joined: 16-May 04 From: Tampa, FL Member No.: 2,073 ![]() |
I would be careful with those mounts. They are fluid filled and known to come apart. Both of mine have come apart. The replacement cost I believe is around 200 each! I will be replacing mine with sti mounts which have to be retrofitted.
Chris H. |
I would be careful with those mounts. They are fluid filled and known to come apart. Both of mine have come apart. The replacement cost I believe is around 200 each! I will be replacing mine with sti mounts which have to be retrofitted. Thanks Andrew, very good point. Yes they are vulnerable and pricey ($271 each at last check). I literally have not moved that thing an inch to keep stress at a minimum. Didn't plan to leave it like that for this long but they seem fine. Seems like this is not the first set for the engine... The bolts arrive tomorrow. |
Lo-Fi Version | Time is now: 19th April 2025 - 03:50 PM |
