> Windshield Washer
lsintampa
post Jun 13 2013, 02:52 PM
75 914/4 2.0
I removed the old tubes for the windshield washer system - all of them. Read the tech article about hooking up motor to the system. Seems very straight forward.
There was a spare tire line that ran to the washer container. I assume it pressurized the tank so when you wanted to squirt some cleaner on your windshield there was something to push the fluid out.
A tube ran out the bottom all the way to the column then went into some turnabout nipple thing and came back out to the nozzles.
My question:
Is that turn around nipple thing the "release" of pressure that will allow fluid to flow?
That means it's mechanical? Or is it? Just curious how it works.
I noticed that there also is a switch that makes contact in the steering column when you pull back on the wiper arm. On my car, the black/brown wire up front was just cut off and hanging out. I'm not sure if I have intermittent wipers or not. There's no sign of a relay of any kind on the brace where the wiper motor is. Don't know how to tell, unless all 75's had em.
Anyway, I'm hoping that black/brown goes hot when the wiper arm is pulled back, cause that's how I hooking the washer motor up.
I'm really starting to enjoy this thing... gets better each day.
Len
Mike Bellis
post Jun 13 2013, 03:16 PM
Resident Electrician
There is a mechanical valve in the turn signal stalk. I'm surprised we don't hear about leaking steering columns more often...
lsintampa   Windshield Washer   Jun 13 2013, 02:52 PM
kg6dxn   There is a mechanical valve in the turn signal sta...   Jun 13 2013, 03:16 PM
lsintampa   There is a mechanical valve in the turn signal st...   Jun 13 2013, 03:47 PM
Dave_Darling   There is a mechanical valve in the turn signal st...   Jun 13 2013, 06:54 PM
tomeric914   I am told that you can use a 924 wiper stalk and ...   Jun 30 2017, 06:38 PM
Valy   [quote name='Dave_Darling' post='1879578' date='J...   Jun 30 2017, 08:23 PM
orthobiz   The intermittent wiper is an additional position f...   Jun 13 2013, 03:52 PM
orthobiz   As a footnote, when Brad Mayeur spruced up my car ...   Jun 13 2013, 07:39 PM
bandjoey   See the classic thread. Someone here (Sir Andy?). ...   Jun 13 2013, 09:15 PM
23e Heure   See the classic thread. Someone here (Sir Andy?)....   May 30 2017, 01:39 PM
914_teener   http://www.914world.com/specs/tech_art.php   May 30 2017, 03:07 PM
914Sixer   The key to doing the conversion is the switch. Re...   May 30 2017, 03:08 PM
kgruen2   The key to doing the conversion is the switch. R...   May 31 2017, 02:10 AM
Olympic 914   The key to doing the conversion is the switch. ...   May 31 2017, 06:40 PM
kgruen2   [quote name='kgruen2' post='2491428' date='May 31...   Jun 1 2017, 01:56 AM
Firstcar   Anyone know the correct ID of the rubber tubing? ...   May 31 2017, 06:24 PM
rpc   Anyone know the correct ID of the rubber tubing? ...   Sep 11 2017, 05:31 PM
9fourteen14   75 914/4 2.0 I removed the old tubes for the win...   Jun 28 2017, 08:12 PM
Dave_Darling   Is the hose from the washer hooked up to the spare...   Jun 29 2017, 12:17 AM
9fourteen14   Problem: when i pull the washer switch towards ...   Jun 29 2017, 03:30 PM
kgruen2   The pressure in the spare tire needs to be greater...   Jun 30 2017, 03:31 AM
9fourteen14   hey guess what guys i was not putting enough air i...   Jul 1 2017, 04:33 AM
kgruen2   This was my solution to the toggle switch for wind...   Jul 3 2017, 02:38 PM
12 User(s) are reading this topic (12 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th April 2025 - 07:58 PM
