> CV Joint Re-Hab, Done!!!! Down off the Jack Stands- Time to Drive
914_teener
post Jun 21 2013, 06:14 PM
Ok...so ready to dip in and re-hab the rear suspension. Part collection is almost complete except new shocks. So a couple of question for the group since I have never taken the CV's apart.
I have read all the other posts and watched the CV You Tube rebuild, and a couple of questions came up in my mind.
1. As of right now there is no "clunking" so I assume that they are not overly worn since they are NLA. Should I just "flip" them when I am done upon reassembly?
2. Do I just flip them end over on the same side of the car? The video didn't explain it very well. So I would assume just reassemble them as they are now and them flip them right?
3. If I see bad pitting or fracturing....should I just look for a used one now and hang on to it?
I have read about all the replacement options, must of them require some machining. I don't want to do this one again very soon so I want to make sure I do it right since the rest of the rear suspension will be getting re-habed.
Thanks all in Advance:
Rob
ThePaintedMan
post Jun 21 2013, 09:11 PM
I just disassembled them, cleaned all the old grease out, installed NEW boots and repacked with quality grease. If you want to flip them (I did as well), all you need to do is mark which end is the inner/outer on each side of the car. Rebuild each side of each half and install them with the old outer side as the new inner. That way they will rotate in the opposite direction.
6freak
post Jun 21 2013, 09:51 PM
MR.C
QUOTE(ThePaintedMan @ Jun 21 2013, 08:11 PM) *
Not saying you can`t but IMO they rotate on the same surface area just a different direction,,,anywho if you see pitting and fretting there done for and need replace,like you said do it right the first time,spend the money and buy new used is just that ..JMO good luck and use Molylub
914_teener
post Jun 22 2013, 10:29 AM
QUOTE(6freak @ Jun 21 2013, 08:51 PM) *
Thanks guys......
Oh though.....using Swepco for the grease.
Thanks for the help. Hopefully everything goes back together well.
914_teener   CV Joint Re-Hab   Jun 21 2013, 06:14 PM
ThePaintedMan   I just disassembled them, cleaned all the old grea...   Jun 21 2013, 09:11 PM
6freak   I just disassembled them, cleaned all the old gre...   Jun 21 2013, 09:51 PM
914_teener   I just disassembled them, cleaned all the old gr...   Jun 22 2013, 10:29 AM
rjames   You'll probably see pitting. If you do, replac...   Jun 22 2013, 01:14 PM
914_teener   Okay....update. Yes for all that have not done t...   Aug 13 2013, 11:08 PM
Chris H.   Yes for all that have not done these.....they ar...   Aug 14 2013, 08:44 AM
914_teener   Yes for all that have not done these.....they a...   Aug 14 2013, 09:31 AM
Racer Chris   1. The Type I's have a recess here shown whe...   Aug 28 2013, 06:28 AM
r_towle   1. The Type I's have a recess here shown wh...   Aug 28 2013, 06:46 AM
76-914   Rob, they never slung any grease out of that side ...   Aug 14 2013, 08:10 AM
cwpeden   Rob, they never slung any grease out of that side...   Aug 16 2013, 03:38 PM
76-914   Rob, I was trying to say they won't or didn...   Aug 14 2013, 04:06 PM
914_teener   Ok. Decided to use 500 degree and most grease res...   Aug 16 2013, 12:18 PM
76-914   Rob, after you do this once you can be a professio...   Aug 16 2013, 01:53 PM
914_teener   Rob, after you do this once you can be a professi...   Aug 16 2013, 09:33 PM
76-914   You did see where these are modified type 1's?...   Aug 16 2013, 07:06 PM
cwpeden   You did see where these are modified type 1's...   Aug 25 2013, 11:38 AM
914_teener   You did see where these are modified type 1...   Aug 25 2013, 12:42 PM
76-914   Yes and Erc along with others warned me. Being old...   Aug 25 2013, 12:45 PM
914_teener   ok. CV's are in. NO gaskets but black hi torq...   Aug 25 2013, 01:31 PM
914_teener   Whew....finally done after about two months up on ...   Aug 27 2013, 11:46 PM
wndsnd   Looks really good. One of the last jobs I need to...   Aug 28 2013, 06:12 AM
914_teener   :D Got it....might relapse! Had I known Dr....   Aug 28 2013, 09:18 AM
- Lo-Fi Version Time is now: 6th January 2025 - 03:30 PM
