> CV Joint Re-Hab, Done!!!! Down off the Jack Stands- Time to Drive
914_teener
post Jun 21 2013, 06:14 PM
Ok...so ready to dip in and re-hab the rear suspension. Part collection is almost complete except new shocks. So a couple of question for the group since I have never taken the CV's apart.
I have read all the other posts and watched the CV You Tube rebuild, and a couple of questions came up in my mind.
1. As of right now there is no "clunking" so I assume that they are not overly worn since they are NLA. Should I just "flip" them when I am done upon reassembly?
2. Do I just flip them end over on the same side of the car? The video didn't explain it very well. So I would assume just reassemble them as they are now and them flip them right?
3. If I see bad pitting or fracturing....should I just look for a used one now and hang on to it?
I have read about all the replacement options, must of them require some machining. I don't want to do this one again very soon so I want to make sure I do it right since the rest of the rear suspension will be getting re-habed.
Thanks all in Advance:
Rob
rjames
post Jun 22 2013, 01:14 PM
I'm made of metal
You'll probably see pitting. If you do, replace them. There are a couple of vendors that sell modified type I replacements.
914_teener   CV Joint Re-Hab   Jun 21 2013, 06:14 PM
ThePaintedMan   I just disassembled them, cleaned all the old grea...   Jun 21 2013, 09:11 PM
6freak   I just disassembled them, cleaned all the old gre...   Jun 21 2013, 09:51 PM
914_teener   I just disassembled them, cleaned all the old gr...   Jun 22 2013, 10:29 AM
rjames   You'll probably see pitting. If you do, replac...   Jun 22 2013, 01:14 PM
914_teener   Okay....update. Yes for all that have not done t...   Aug 13 2013, 11:08 PM
Chris H.   Yes for all that have not done these.....they ar...   Aug 14 2013, 08:44 AM
914_teener   Yes for all that have not done these.....they a...   Aug 14 2013, 09:31 AM
Racer Chris   1. The Type I's have a recess here shown whe...   Aug 28 2013, 06:28 AM
r_towle   1. The Type I's have a recess here shown wh...   Aug 28 2013, 06:46 AM
76-914   Rob, they never slung any grease out of that side ...   Aug 14 2013, 08:10 AM
cwpeden   Rob, they never slung any grease out of that side...   Aug 16 2013, 03:38 PM
76-914   Rob, I was trying to say they won't or didn...   Aug 14 2013, 04:06 PM
914_teener   Ok. Decided to use 500 degree and most grease res...   Aug 16 2013, 12:18 PM
76-914   Rob, after you do this once you can be a professio...   Aug 16 2013, 01:53 PM
914_teener   Rob, after you do this once you can be a professi...   Aug 16 2013, 09:33 PM
76-914   You did see where these are modified type 1's?...   Aug 16 2013, 07:06 PM
cwpeden   You did see where these are modified type 1's...   Aug 25 2013, 11:38 AM
914_teener   You did see where these are modified type 1...   Aug 25 2013, 12:42 PM
76-914   Yes and Erc along with others warned me. Being old...   Aug 25 2013, 12:45 PM
914_teener   ok. CV's are in. NO gaskets but black hi torq...   Aug 25 2013, 01:31 PM
914_teener   Whew....finally done after about two months up on ...   Aug 27 2013, 11:46 PM
wndsnd   Looks really good. One of the last jobs I need to...   Aug 28 2013, 06:12 AM
914_teener   :D Got it....might relapse! Had I known Dr....   Aug 28 2013, 09:18 AM
- Lo-Fi Version Time is now: 6th January 2025 - 03:17 PM
