tumamilhem |
LUFTBRIGADE ![]() ![]() ![]() Group: Members Posts: 1,228 Joined: 29-October 12 From: Jacksonville, FL Member No.: 15,092 Region Association: South East States ![]() |
This very nice 1975 914 is my second of three. I'm only selling it because I have another and a VW as my daily driver and cannot keep three cars. It's garage kept the duration of the 8 years I've owned it and was my only car and daily driver for 5 years until I bought a second car. Engine has been completely rebuilt by local 914 specialist 'Chief' and made more powerful with the replacement of larger 96mm pistons, bore and jugs. Original fuel injection runs great and has rebuilt air flow meter. No rust underneath the car, nor in the floor pans. Even the typical, dreaded "hell hole" has no rust (as seen in pic), nor the battery stand. This is a SOLID 914 and in very good condition. I have a detailed list for all mechanics serviced, documentation and receipts for all work.
Car is in original paint color of Scarlet Red (Porsche color code L31M) EVERY ORIGINAL FACTORY OPTION INCLUDED: - Rear Window Defroster - Full Center Console with Gauges - Leather Wrapped Steering Wheel - Leather Shift Boot - Dual Horns - Factory Carpeting - Middle Seat / Armrest - Center Storage Box - Fog Lights WORK/SERVICE/IMPROVEMENTS DONE: - /4 Engine completely rebuilt (new heads, pistons, valves, gaskets, etc.). - Added larger pistons, bore and jugs for more horsepower (2.2). - Original L-jet fuel injection works great. - New air flow meter for fuel injection. - Side shifter transmission serviced. - New distributor. - New fuel pump. - Installed hot start to eliminate need for points. - Interior is in very nice shape. - Appearance Package center console with all working gauges (volt, oil temp, clock). - All knobs in dash work and are in excellent shape. - Dash back in great shape. Front dash has cover. - Original leather wrapped steering wheel. - Factory carpet in great shape. - Original speaker grills. - Back pad in great shape. - Seats in good shape. They have a couple rips in the side that can easily be mended or be recovered. - Pop-up headlamps and factory option fog lights all work and in great condition. - Pop-up headlamp motors replaced. - Targa hard top in excellent shape, no scratches, fading, etc. Still has original headliner carpeting - doesn't sag. - Original factory wheels plus spare wheel. - Brand new BF Goodrich G-Force performance tires. - Front and rear bumpers are in excellent shape. - Original side mirror in great shape. - Engine grille in great shape. - Larger (front) calipers on rear. - New starter - L-jet fuel injection works great with newly rebuilt air flow meter - New bearings - New crank shaft - New push rods - New gasket kit - Replaced fan - New fan belt - New speedometer cable - New motor mounts - Replaced fly wheel - New larger oil cooler, cooler adapters, fittings, liners - New set of shifter bushings - Replaced ignition coil - Replaced fuel pressure regulator - Repainted wire harness to dual fuel relay - Cleaned all grounds to maintain harness under circuit block and relays Mechanical work done by a well-known experienced local Porsche mechanic and 914 authority 'Chief' at Pistons and Rotors, local 914 guru and well-known 914 World member 'Dr.' Phil Sparta (the Porsche doctor) know who had owned 18 914s and restored many, Overby's in Jacksonville, FL (exotic car dealer/shop) and Automobile Atlanta in Marietta, GA (914 specialists). I have receipts and documentation for all the new/rebuilt parts and services. One rear engine lid arm bracket needs to be re-attached. I don't know how to re-attach it as I've never removed the engine lid before. Paint is in good shape save a few flaws from being a daily driver for many years. Outside of car was repainted the same, original color once prior to my ownership. Inside of car is original paint. Car is sitting pretty in dry storage out of harmful elements. Very nice 914 more than reasonably priced at $10K Email: tuma_milhem@yahoo.com Call: 904-737-0287 (If not home, leave a message) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Stickers have been removed ![]() |
tumamilhem |
Lo-Fi Version | Time is now: 20th June 2024 - 05:48 AM |
