> 75 LJet will not fire, finishing restoration
malcolm2
post Jun 28 2013, 10:45 PM
Ok I think I am good on the seat belt relay. YLW and YLW/red are spliced. And I have checked for continuity all the way from the starter to the key on that wire.
I have spark, points checked too.
I have fuel pressure, about 40 psi, checked between p-side fuel rail and cold start valve.
Starter works fine
oil pressure builds, light goes out on the dash
Engine timing is still at rebuild setting...0 TDC.
Re-built FI & Ignition & Alt harnesses
I did have trouble with the key switch, so the steering wheel is out, levers are not connected and I turn a screw driver on the end of the key connector to fire the starter, should not be an issue, correct?
I got the L-jet trouble shooting "no start" pages to try tomorrow.
Any other ideas? I am baffled. (IMG:style_emoticons/default/confused24.gif)
jim_hoyland
post Jun 29 2013, 07:21 AM
Get that VIN ?
My favorite no-start issues have been:
1. Yellow wire at rear of harness not connected to the 4 spade plug
2. Black ignition wire on negative side of coil
3. The 6-pin plug that goes into the AFM is unplugged or loose
4. The ground wire from the dual relay is not connected, it goes onto a spade in the middle of the engine case
5. White FI wire,along with tach wire, not on the negative terminal of coil
6. Lastly, a bad connection at the + battery of one of the red wires. Two reds go to the 14 pin connected at thr front of the relay board.
Good luck, been there; tell us what you find out
Rockaria
post Jun 29 2013, 09:53 AM
ZippidyDoDah...
QUOTE(jim_hoyland @ Jun 29 2013, 07:21 AM) *
Done this before... A few times.... So embarrassing (IMG:style_emoticons/default/dry.gif) Harder to admit! My final solution, sell the 75 and buy a 73. All better.
Also check the resistor pack (The 4 cigaretts in a metal sleeve) they can come loose. (not only the connector... inside at the white parts, the connection can break.)
malcolm2   75 LJet will not fire   Jun 28 2013, 10:45 PM
timothy_nd28   Can you post a few pics, so we can rule out anythi...   Jun 28 2013, 11:58 PM
malcolm2   Can you post a few pics, so we can rule out anyth...   Jun 29 2013, 07:05 AM
jim_hoyland   My favorite no-start issues have been: 1. Yellow w...   Jun 29 2013, 07:21 AM
Rockaria   My favorite no-start issues have been: ... 3. The...   Jun 29 2013, 09:53 AM
timothy_nd28   Okay, so the car turns over and you already verifi...   Jun 29 2013, 09:33 AM
malcolm2   Okay, so the car turns over and you already verif...   Jun 29 2013, 02:04 PM
jim_hoyland   Another thing I would ask: Does the engine start f...   Jun 29 2013, 10:13 AM
malcolm2   Morning tests lead me to the Injectors. I pulled ...   Jun 29 2013, 11:59 AM
timothy_nd28   Did you have 12vdc on pin 10 on the ECU connector?   Jun 29 2013, 12:01 PM
timothy_nd28   If you don't have 12v at pin 10 you won't ...   Jun 29 2013, 12:10 PM
malcolm2   BTW, You won't have much luck reading voltag...   Jun 29 2013, 02:10 PM
malcolm2   If you don't have 12v at pin 10 you won't...   Jun 29 2013, 02:16 PM
timothy_nd28   If you don't have 12v at pin 10 you won...   Jun 29 2013, 02:19 PM
jim_hoyland   I assume the resister pack is plugged in; you may ...   Jun 29 2013, 01:26 PM
Sleepin   Every time mine hasn't started (each time in t...   Jun 29 2013, 01:37 PM
timothy_nd28   Good, now with the ECU connector off, measure pins...   Jun 29 2013, 02:16 PM
malcolm2   Good, now with the ECU connector off, measure pin...   Jun 29 2013, 02:20 PM
timothy_nd28   I'm not home, give me a hour to reply   Jun 29 2013, 02:52 PM
malcolm2   I'm not home, give me a hour to reply ANY ...   Jun 29 2013, 02:55 PM
timothy_nd28   Okay, with one meter lead on pin 10 (ECU connector...   Jun 29 2013, 03:36 PM
malcolm2   Okay, with one meter lead on pin 10 (ECU connecto...   Jun 29 2013, 04:21 PM
timothy_nd28   Pin 5, 16 and 17 should all be grounds. This coul...   Jun 29 2013, 04:26 PM
malcolm2   Pin 5, 16 and 17 should all be grounds. This cou...   Jun 29 2013, 04:32 PM
timothy_nd28   You should of had 12 volts from pin 10 to 5,,pin 1...   Jun 29 2013, 04:36 PM
malcolm2   You should of had 12 volts from pin 10 to 5, pin ...   Jun 29 2013, 04:43 PM
timothy_nd28   Yah, don't tear into your fresh harness. Do y...   Jun 29 2013, 04:46 PM
malcolm2   Yah, don't tear into your fresh harness. Do ...   Jun 29 2013, 06:04 PM
malcolm2   Yah, don't tear into your fresh harness. Do...   Jun 29 2013, 06:27 PM
timothy_nd28   Is it possible to remove the black plastic ECU ...   Jun 29 2013, 05:35 PM
timothy_nd28   Good, but we are running out of things to check. ...   Jun 29 2013, 06:35 PM
malcolm2   Good, but we are running out of things to check. ...   Jun 29 2013, 06:55 PM
pilothyer   I have heard about starting cars with starting f...   Jun 30 2013, 08:44 AM
Black22   I have heard about starting cars with starting ...   Jun 30 2013, 10:06 AM
malcolm2   [quote name='pilothyer' post='1887430' date='Jun ...   Jun 30 2013, 11:02 AM
timothy_nd28   The car will run off ether, pull off the AFM and s...   Jun 29 2013, 07:12 PM
malcolm2   The car will run off ether, pull off the AFM and ...   Jun 29 2013, 07:31 PM
timothy_nd28   I have little faith with parts laying in some box....   Jun 29 2013, 07:50 PM
malcolm2   I have little faith with parts laying in some box...   Jun 29 2013, 09:11 PM
timothy_nd28   How fancy is your meter, does it check dc amps? Y...   Jun 29 2013, 09:15 PM
malcolm2   How fancy is your meter, does it check dc amps? ...   Jun 29 2013, 09:21 PM
timothy_nd28   Yah, you should hear a slight click, but I think t...   Jun 29 2013, 09:27 PM
malcolm2   Yah, you should hear a slight click, but I think ...   Jun 29 2013, 09:38 PM
timothy_nd28   Pull the injectors and send them to Witch Hunters....   Jun 29 2013, 10:11 PM
malcolm2   Pull the injectors and send them to Witch Hunters...   Jun 30 2013, 07:56 AM
Jeff Bowlsby   Hey Clark, Tim, I have only loosely followed this...   Jun 29 2013, 11:10 PM
timothy_nd28   Never mind the amp meter. I'm fairly certain ...   Jun 30 2013, 09:46 AM
malcolm2   Soaking the injectors and using a 9v battery did n...   Jul 1 2013, 12:00 PM
jim_hoyland   Is there a method for storing injectors that are g...   Jul 1 2013, 01:03 PM
malcolm2   Is there a method for storing injectors that are ...   Jul 1 2013, 02:55 PM
timothy_nd28   Is there a method for storing injectors that are...   Jul 1 2013, 03:01 PM
Jeff Bowlsby   I was secretly hoping failure and you would give ...   Jul 1 2013, 07:01 PM
timothy_nd28   I was secretly hoping failure and you would give...   Jul 1 2013, 10:27 PM
r_towle   I have had very good success using Tektron FI clea...   Jul 1 2013, 03:02 PM
Black22   I run straight Marvel Mystery Oil through them bef...   Jul 1 2013, 06:28 PM
malcolm2   Small celebration tonight. A forum friend here in...   Jul 2 2013, 08:54 PM
timothy_nd28   :Qarl:   Jul 2 2013, 08:57 PM
Jeff Bowlsby   Oh yea... ;)   Jul 2 2013, 09:42 PM
17 User(s) are reading this topic (17 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 01:40 PM
