> 75 LJet will not fire, finishing restoration
malcolm2
post Jun 28 2013, 10:45 PM
Ok I think I am good on the seat belt relay. YLW and YLW/red are spliced. And I have checked for continuity all the way from the starter to the key on that wire.
I have spark, points checked too.
I have fuel pressure, about 40 psi, checked between p-side fuel rail and cold start valve.
Starter works fine
oil pressure builds, light goes out on the dash
Engine timing is still at rebuild setting...0 TDC.
Re-built FI & Ignition & Alt harnesses
I did have trouble with the key switch, so the steering wheel is out, levers are not connected and I turn a screw driver on the end of the key connector to fire the starter, should not be an issue, correct?
I got the L-jet trouble shooting "no start" pages to try tomorrow.
Any other ideas? I am baffled. (IMG:style_emoticons/default/confused24.gif)
timothy_nd28
post Jun 29 2013, 12:10 PM
If you don't have 12v at pin 10 you won't have voltage at pins 14,15,32 and 33 either. Run a temp jumper on the dual relay pin 88a to the positive battery post and try starting the car.
BTW, You won't have much luck reading voltages at the fuel injector connector. The voltage will be a quick blip and most modern multimeters won't measure it. Unless you're using an analog meter, this would allow you to see the meter needle sweep back and forth.
malcolm2
post Jun 29 2013, 02:10 PM
QUOTE(timothy_nd28 @ Jun 29 2013, 01:10 PM) *
That is what I thought might happen. My meter is digital.
malcolm2   75 LJet will not fire   Jun 28 2013, 10:45 PM
timothy_nd28   Can you post a few pics, so we can rule out anythi...   Jun 28 2013, 11:58 PM
malcolm2   Can you post a few pics, so we can rule out anyth...   Jun 29 2013, 07:05 AM
jim_hoyland   My favorite no-start issues have been: 1. Yellow w...   Jun 29 2013, 07:21 AM
Rockaria   My favorite no-start issues have been: ... 3. The...   Jun 29 2013, 09:53 AM
timothy_nd28   Okay, so the car turns over and you already verifi...   Jun 29 2013, 09:33 AM
malcolm2   Okay, so the car turns over and you already verif...   Jun 29 2013, 02:04 PM
jim_hoyland   Another thing I would ask: Does the engine start f...   Jun 29 2013, 10:13 AM
malcolm2   Morning tests lead me to the Injectors. I pulled ...   Jun 29 2013, 11:59 AM
timothy_nd28   Did you have 12vdc on pin 10 on the ECU connector?   Jun 29 2013, 12:01 PM
timothy_nd28   If you don't have 12v at pin 10 you won't ...   Jun 29 2013, 12:10 PM
malcolm2   BTW, You won't have much luck reading voltag...   Jun 29 2013, 02:10 PM
malcolm2   If you don't have 12v at pin 10 you won't...   Jun 29 2013, 02:16 PM
timothy_nd28   If you don't have 12v at pin 10 you won...   Jun 29 2013, 02:19 PM
jim_hoyland   I assume the resister pack is plugged in; you may ...   Jun 29 2013, 01:26 PM
Sleepin   Every time mine hasn't started (each time in t...   Jun 29 2013, 01:37 PM
timothy_nd28   Good, now with the ECU connector off, measure pins...   Jun 29 2013, 02:16 PM
malcolm2   Good, now with the ECU connector off, measure pin...   Jun 29 2013, 02:20 PM
timothy_nd28   I'm not home, give me a hour to reply   Jun 29 2013, 02:52 PM
malcolm2   I'm not home, give me a hour to reply ANY ...   Jun 29 2013, 02:55 PM
timothy_nd28   Okay, with one meter lead on pin 10 (ECU connector...   Jun 29 2013, 03:36 PM
malcolm2   Okay, with one meter lead on pin 10 (ECU connecto...   Jun 29 2013, 04:21 PM
timothy_nd28   Pin 5, 16 and 17 should all be grounds. This coul...   Jun 29 2013, 04:26 PM
malcolm2   Pin 5, 16 and 17 should all be grounds. This cou...   Jun 29 2013, 04:32 PM
timothy_nd28   You should of had 12 volts from pin 10 to 5,,pin 1...   Jun 29 2013, 04:36 PM
malcolm2   You should of had 12 volts from pin 10 to 5, pin ...   Jun 29 2013, 04:43 PM
timothy_nd28   Yah, don't tear into your fresh harness. Do y...   Jun 29 2013, 04:46 PM
malcolm2   Yah, don't tear into your fresh harness. Do ...   Jun 29 2013, 06:04 PM
malcolm2   Yah, don't tear into your fresh harness. Do...   Jun 29 2013, 06:27 PM
timothy_nd28   Is it possible to remove the black plastic ECU ...   Jun 29 2013, 05:35 PM
timothy_nd28   Good, but we are running out of things to check. ...   Jun 29 2013, 06:35 PM
malcolm2   Good, but we are running out of things to check. ...   Jun 29 2013, 06:55 PM
pilothyer   I have heard about starting cars with starting f...   Jun 30 2013, 08:44 AM
Black22   I have heard about starting cars with starting ...   Jun 30 2013, 10:06 AM
malcolm2   [quote name='pilothyer' post='1887430' date='Jun ...   Jun 30 2013, 11:02 AM
timothy_nd28   The car will run off ether, pull off the AFM and s...   Jun 29 2013, 07:12 PM
malcolm2   The car will run off ether, pull off the AFM and ...   Jun 29 2013, 07:31 PM
timothy_nd28   I have little faith with parts laying in some box....   Jun 29 2013, 07:50 PM
malcolm2   I have little faith with parts laying in some box...   Jun 29 2013, 09:11 PM
timothy_nd28   How fancy is your meter, does it check dc amps? Y...   Jun 29 2013, 09:15 PM
malcolm2   How fancy is your meter, does it check dc amps? ...   Jun 29 2013, 09:21 PM
timothy_nd28   Yah, you should hear a slight click, but I think t...   Jun 29 2013, 09:27 PM
malcolm2   Yah, you should hear a slight click, but I think ...   Jun 29 2013, 09:38 PM
timothy_nd28   Pull the injectors and send them to Witch Hunters....   Jun 29 2013, 10:11 PM
malcolm2   Pull the injectors and send them to Witch Hunters...   Jun 30 2013, 07:56 AM
Jeff Bowlsby   Hey Clark, Tim, I have only loosely followed this...   Jun 29 2013, 11:10 PM
timothy_nd28   Never mind the amp meter. I'm fairly certain ...   Jun 30 2013, 09:46 AM
malcolm2   Soaking the injectors and using a 9v battery did n...   Jul 1 2013, 12:00 PM
jim_hoyland   Is there a method for storing injectors that are g...   Jul 1 2013, 01:03 PM
malcolm2   Is there a method for storing injectors that are ...   Jul 1 2013, 02:55 PM
timothy_nd28   Is there a method for storing injectors that are...   Jul 1 2013, 03:01 PM
Jeff Bowlsby   I was secretly hoping failure and you would give ...   Jul 1 2013, 07:01 PM
timothy_nd28   I was secretly hoping failure and you would give...   Jul 1 2013, 10:27 PM
r_towle   I have had very good success using Tektron FI clea...   Jul 1 2013, 03:02 PM
Black22   I run straight Marvel Mystery Oil through them bef...   Jul 1 2013, 06:28 PM
malcolm2   Small celebration tonight. A forum friend here in...   Jul 2 2013, 08:54 PM
timothy_nd28   :Qarl:   Jul 2 2013, 08:57 PM
Jeff Bowlsby   Oh yea... ;)   Jul 2 2013, 09:42 PM
19 User(s) are reading this topic (19 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 27th December 2024 - 01:49 PM
