75 LJet will not fire, finishing restoration |
malcolm2 |
Jun 28 2013, 10:45 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Ok I think I am good on the seat belt relay. YLW and YLW/red are spliced. And I have checked for continuity all the way from the starter to the key on that wire.
I have spark, points checked too. I have fuel pressure, about 40 psi, checked between p-side fuel rail and cold start valve. Starter works fine oil pressure builds, light goes out on the dash Engine timing is still at rebuild setting...0 TDC. Re-built FI & Ignition & Alt harnesses I did have trouble with the key switch, so the steering wheel is out, levers are not connected and I turn a screw driver on the end of the key connector to fire the starter, should not be an issue, correct? I got the L-jet trouble shooting "no start" pages to try tomorrow. Any other ideas? I am baffled. (IMG:style_emoticons/default/confused24.gif) |
timothy_nd28 |
Jun 29 2013, 12:10 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
If you don't have 12v at pin 10 you won't have voltage at pins 14,15,32 and 33 either. Run a temp jumper on the dual relay pin 88a to the positive battery post and try starting the car.
BTW, You won't have much luck reading voltages at the fuel injector connector. The voltage will be a quick blip and most modern multimeters won't measure it. Unless you're using an analog meter, this would allow you to see the meter needle sweep back and forth. |
malcolm2 |
Jun 29 2013, 02:16 PM
If you don't have 12v at pin 10 you won't have voltage at pins 14,15,32 and 33 either. Run a temp jumper on the dual relay pin 88a to the positive battery post and try starting the car. Since I have voltage at 88a, there is no since in jumping here, correct? I have voltage at 10 too. |
timothy_nd28 |
Jun 29 2013, 02:19 PM
If you don't have 12v at pin 10 you won't have voltage at pins 14,15,32 and 33 either. Run a temp jumper on the dual relay pin 88a to the positive battery post and try starting the car. Since I have voltage at 88a, there is no since in jumping here, correct? I have voltage at 10 too. correct, it would be redundant. Check those pins on the ECU connector that I described above. |
Lo-Fi Version | Time is now: 27th December 2024 - 01:36 PM |
