chads74 |
Member ![]() ![]() Group: Members Posts: 386 Joined: 13-March 12 From: Tampa, FL Member No.: 14,252 Region Association: South East States ![]() |
Is there a way to test the voltage regulator to see if it is still good? I had my alternator tested and its good, so I am left scratching my head.
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Aside from doing its job, regulating the voltage, its always been a go nogo thing for me.
Either it works or it does not. If you check voltage at the battery with the car running, it should be 14VDC or somewhere in that range. Then you know the charging system is clean and working properly. The VR wont do its job kinda...for me it works or it does not. A weak charging system is typically due to bad ground connections or a weak battery. rich |
Lo-Fi Version | Time is now: 25th June 2024 - 08:31 PM |
