> Weber 44 idf flat spot
tornik550
post Jul 4 2013, 11:59 AM
So I recently purchased new weber 44 idf's. They didn't work out well so I went back to an old set of weber 44 idf's that I had. I thoroughly cleaned the carbs, sprayed carb cleaner through all jets, tubes, etc. I have also balanced the linkage. Set the floats, etc.
The car starts well. Idle's well. When I drive the car I get a major flat spot between 1500 and 3000 rpm's. Below and above the car accelerates normally.
What changes should I make?
My current setup for my 2258 (dual webers, big cam)
-idle 55
-main 160
-et F11
-ac 200
-vents 36
Are there other issues that can cause this type of problem (timing,etc?)
r_towle
post Jul 4 2013, 02:02 PM
Custom Member
f7 or turbo emulsion tubes help with flat spots, as well as smaller venturis, possibly 32mm
rich
tornik550   Weber 44 idf flat spot   Jul 4 2013, 11:59 AM
ThePaintedMan   So I recently purchased new weber 44 idf's. ...   Jul 4 2013, 01:36 PM
Elliot Cannon   So I recently purchased new weber 44 idf's. ...   Jul 4 2013, 01:36 PM
r_towle   f7 or turbo emulsion tubes help with flat spots, a...   Jul 4 2013, 02:02 PM
brant   28 vents. Perhaps 40 mm carbs   Jul 4 2013, 02:24 PM
Starlack   Hello This is the transition area from idle jet t...   Jul 4 2013, 02:41 PM
tornik550   The interesting thing is that my car ran great in ...   Jul 4 2013, 02:57 PM
tornik550   Thinking about this situation, I think the suggest...   Jul 4 2013, 03:12 PM
McMark   The carbs weren't really flowing fuel when the...   Jul 4 2013, 03:16 PM
tornik550   Ok, I am getting a bit pissed off at weber now. ...   Jul 4 2013, 03:45 PM
Racer Chris   So for the record- does the longer side of the se...   Jul 5 2013, 06:55 AM
sean_v8_914   good advice above smaller vents smaller main jets   Jul 4 2013, 04:05 PM
sean_v8_914   long side of taper down. spray hole down   Jul 4 2013, 04:06 PM
sean_v8_914   http://www.carburetion.com/diags/40IDFDiaginfo.asp   Jul 4 2013, 04:07 PM
sean_v8_914   a wide band O2 would be nice for selecting the tru...   Jul 4 2013, 04:09 PM
tornik550   a wide band O2 would be nice for selecting the tr...   Jul 4 2013, 04:17 PM
Mblizzard   On my weber 44s, 28 vents made all the difference....   Jul 4 2013, 04:25 PM
Woody   I run 36 vents and the car runs great. I have a se...   Jul 4 2013, 08:53 PM
McMark   If you take the vent out you'll see one side i...   Jul 4 2013, 11:54 PM
tornik550   I have worked out my flat spot. I found that the ...   Jul 12 2013, 08:15 AM
Racer Chris   I have worked out my flat spot. I found that the...   Jul 12 2013, 08:28 AM
tornik550   I have worked out my flat spot. I found that th...   Jul 12 2013, 08:31 AM
Jake Raby   The only issue that I am having on the wideband...   Jul 12 2013, 06:31 PM
tornik550   The only issue that I am having on the wideban...   Jul 12 2013, 07:46 PM
Racer Chris   If you back off the nuts on the accel pump rods an...   Jul 12 2013, 11:24 AM
ThePaintedMan   I thought I read somewhere that smaller vents gi...   Jul 13 2013, 02:01 PM
Racer Chris   In theory, every form of the Type IV below about ...   Jul 13 2013, 02:46 PM
ThePaintedMan   That is absolutely false. With wideband air/fuel...   Jul 13 2013, 05:38 PM
Racer Chris   But Chris, weren't you suspecting that the en...   Jul 14 2013, 10:01 AM
r_towle   That motor in the red/ white race car had basicall...   Jul 13 2013, 05:06 PM
tornik550   Chris- I followed your instructions on tuning my c...   Jul 14 2013, 07:46 PM
Racer Chris   The true exhaust temp is a lot higher than that. ...   Jul 14 2013, 10:29 PM
26 User(s) are reading this topic (26 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd December 2024 - 07:07 PM
