Weber 44 idf flat spot |
tornik550 |
Jul 4 2013, 11:59 AM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
So I recently purchased new weber 44 idf's. They didn't work out well so I went back to an old set of weber 44 idf's that I had. I thoroughly cleaned the carbs, sprayed carb cleaner through all jets, tubes, etc. I have also balanced the linkage. Set the floats, etc.
The car starts well. Idle's well. When I drive the car I get a major flat spot between 1500 and 3000 rpm's. Below and above the car accelerates normally. What changes should I make? My current setup for my 2258 (dual webers, big cam) -idle 55 -main 160 -et F11 -ac 200 -vents 36 Are there other issues that can cause this type of problem (timing,etc?) |
brant |
Jul 4 2013, 02:24 PM
914 Wizard Group: Members Posts: 11,824 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
28 vents. Perhaps 40 mm carbs
Lo-Fi Version | Time is now: 22nd December 2024 - 06:29 PM |
