> Weber 44 idf flat spot
tornik550
post Jul 4 2013, 11:59 AM
So I recently purchased new weber 44 idf's. They didn't work out well so I went back to an old set of weber 44 idf's that I had. I thoroughly cleaned the carbs, sprayed carb cleaner through all jets, tubes, etc. I have also balanced the linkage. Set the floats, etc.
The car starts well. Idle's well. When I drive the car I get a major flat spot between 1500 and 3000 rpm's. Below and above the car accelerates normally.
What changes should I make?
My current setup for my 2258 (dual webers, big cam)
-idle 55
-main 160
-et F11
-ac 200
-vents 36
Are there other issues that can cause this type of problem (timing,etc?)
tornik550
post Jul 4 2013, 03:45 PM
Ok, I am getting a bit pissed off at weber now. The way that I realized that my secondary vents were in up side down was because when I purchased my new webers I saw that the new secondary vents were installed opposite to mine. I assumed that the carbs from the weber factory were correct. I just looked at a diagram and I think that my carbs were correct and the carbs from weber were up side down, wtf!
So for the record- does the longer side of the secondary vent point towards or away from the butterfly? Does the angle where the fuel comes out point towards or away from the butterflies?
tornik550   Weber 44 idf flat spot   Jul 4 2013, 11:59 AM
ThePaintedMan   So I recently purchased new weber 44 idf's. ...   Jul 4 2013, 01:36 PM
Elliot Cannon   So I recently purchased new weber 44 idf's. ...   Jul 4 2013, 01:36 PM
r_towle   f7 or turbo emulsion tubes help with flat spots, a...   Jul 4 2013, 02:02 PM
brant   28 vents. Perhaps 40 mm carbs   Jul 4 2013, 02:24 PM
Starlack   Hello This is the transition area from idle jet t...   Jul 4 2013, 02:41 PM
tornik550   The interesting thing is that my car ran great in ...   Jul 4 2013, 02:57 PM
tornik550   Thinking about this situation, I think the suggest...   Jul 4 2013, 03:12 PM
McMark   The carbs weren't really flowing fuel when the...   Jul 4 2013, 03:16 PM
tornik550   Ok, I am getting a bit pissed off at weber now. ...   Jul 4 2013, 03:45 PM
Racer Chris   So for the record- does the longer side of the se...   Jul 5 2013, 06:55 AM
sean_v8_914   good advice above smaller vents smaller main jets   Jul 4 2013, 04:05 PM
sean_v8_914   long side of taper down. spray hole down   Jul 4 2013, 04:06 PM
sean_v8_914   http://www.carburetion.com/diags/40IDFDiaginfo.asp   Jul 4 2013, 04:07 PM
sean_v8_914   a wide band O2 would be nice for selecting the tru...   Jul 4 2013, 04:09 PM
tornik550   a wide band O2 would be nice for selecting the tr...   Jul 4 2013, 04:17 PM
Mblizzard   On my weber 44s, 28 vents made all the difference....   Jul 4 2013, 04:25 PM
Woody   I run 36 vents and the car runs great. I have a se...   Jul 4 2013, 08:53 PM
McMark   If you take the vent out you'll see one side i...   Jul 4 2013, 11:54 PM
tornik550   I have worked out my flat spot. I found that the ...   Jul 12 2013, 08:15 AM
Racer Chris   I have worked out my flat spot. I found that the...   Jul 12 2013, 08:28 AM
tornik550   I have worked out my flat spot. I found that th...   Jul 12 2013, 08:31 AM
Jake Raby   The only issue that I am having on the wideband...   Jul 12 2013, 06:31 PM
tornik550   The only issue that I am having on the wideban...   Jul 12 2013, 07:46 PM
Racer Chris   If you back off the nuts on the accel pump rods an...   Jul 12 2013, 11:24 AM
ThePaintedMan   I thought I read somewhere that smaller vents gi...   Jul 13 2013, 02:01 PM
Racer Chris   In theory, every form of the Type IV below about ...   Jul 13 2013, 02:46 PM
ThePaintedMan   That is absolutely false. With wideband air/fuel...   Jul 13 2013, 05:38 PM
Racer Chris   But Chris, weren't you suspecting that the en...   Jul 14 2013, 10:01 AM
r_towle   That motor in the red/ white race car had basicall...   Jul 13 2013, 05:06 PM
tornik550   Chris- I followed your instructions on tuning my c...   Jul 14 2013, 07:46 PM
Racer Chris   The true exhaust temp is a lot higher than that. ...   Jul 14 2013, 10:29 PM
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd December 2024 - 06:30 PM
