dale73914 |
Member ![]() ![]() Group: Members Posts: 209 Joined: 15-September 11 From: Victoria, Australia Member No.: 13,562 Region Association: Australia and New Zealand ![]() |
Hi All,
Was snooping around youtube ( after looking at the Pikes Peak post ) and saw a video of a 914 that has me interested. In the ashtray area there are some gauges mounted. As my next job is to put oil temp and pressures gauges in, this looks pretty cool to me. I dont have a console and have the radio in an underdash housing , so cant use a normal 2 gauge plate mount in the centre ( and dont really want to either ) My question is, has anyone done this, and did it involve any cutting. I dont want to do anything i couldnt pull out again later if i wanted. The video for anyone interested is http://www.youtube.com/watch?v=gTO7JVt8FZE Cheers Dale Attached image(s) ![]() |
dale73914 |
ok, so looks like this is definitely doable then. Thanks for your replies.
Will look into the various options and try and pick myself up some gauges and sensors etc. Anything I need to know about mounting the sensors ? Do I need any specific VDO part number to suit these things, or just the standard one that will come with the oil pressure and temp gauge. Also, should I be looking at a particular temp range ? Sorry if this sounds dumb, but these cars are still pretty new to me. Should I buy from someone in particular ?? Anyone here maybe ? rather buy right first time.... Cheers Dale |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
Anything I need to know about mounting the sensors ? Do I need any specific VDO part number to suit these things, or just the standard one that will come with the oil pressure and temp gauge. Also, should I be looking at a particular temp range ? Most state the diameter of the hole and diameter of the gauge. I think it's 2-1/8" but check the specs to make sure. Oil temp max less than 275ish degrees F; 250 degrees F oil temp too high... I'd buy from world vendors first, cheapest next... |
Lo-Fi Version | Time is now: 24th June 2024 - 06:55 AM |
