tornik550 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None ![]() |
For the past year, I have been fighting my innovate lc1 setup. It would work under certain circumstances. I never really trusted the readings. Everything was setup properly and calibrated properly. I just got fed up and got an AEM setup. Installed it, started right up. Turns out that my innovate readings were really inaccurate. I was having a super difficult time tuning my carbs cause I was getting strange readings. Now with the AEM, it turns out that my carbs are pretty close to where they should be (IMG:style_emoticons/default/headbang.gif)
Very please with the AEM setup. |
iamchappy |
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest ![]() ![]() |
I removed the sensor today, cleaned it up and blew it out before doing a free air calibration. the Lc-1 did work better today but pegs at 18 for a few seconds in between shifts when on boost, before returning to normal operation. It could be because of flames shooting out my tail pipe but dont know for sure if flames are, may need to hook up the Go-Pro to check on that......
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I removed the sensor today, cleaned it up and blew it out before doing a free air calibration. the Lc-1 did work better today but pegs at 18 for a few seconds in between shifts when on boost, before returning to normal operation. It could be because of flames shooting out my tail pipe but dont know for sure if flames are, may need to hook up the Go-Pro to check on that...... All that matters with any wideband is the reading under load. (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 30th June 2024 - 11:57 PM |
