> Door latch repair....., The importance of maintenance
billh1963
post Jul 13 2013, 02:34 PM
Car Hoarder!
This is old news to those who have been around 914's for a while. But, for the newer owners this might be useful:
Decided today was a good day to fix 914 door latches. Two cars had inoperative passenger outside door latches and the drivers door on one of them was getting harder to open. I knew at that rate it wouldn't be long and I would be locked out of the car!
Did the normal research (thread searches, reviewed the procedures in the Porsche workshop manual, etc) and figured I knew what to do. The plan was to replace the plastic cam pieces (I had purchased four new ones a couple of months ago) and clean/degrease the latch assemblies.
The first door I tackled (inoperative outside latch on passenger door) had a broken cam as suspected. The cam was black. Isn't that a replacement unit? The latch mechanism inside the door was very grungy. Experimentation between purple power, simply green , gunk engine degreaser and brake cleaner showed that the best results were obtained by spraying the mechanism with gunk engine degreaser (gel) and letting it sit for 15-20 minutes. Rinse off and follow up with brake cleaner. YMMV. I sprayed the moving pieces with white lihium grease before reassembly. I cannot explain how nicely the door operates now. Just a slight pull on the door handle and the door pops open.
The second door was the "good" drivers door. The cam looks to be original (white plastic) and in perfect shape. The door mechanism was very dirty and operated sluggishly. A good cleaning and the door now pops open with a light pull.
The main purpose of this post is a warning on what was found on the other car. On that car the passenger door was not opening with the outside handle and it took a lot of effort to open the drivers door with the outside handle. On both doors, the cam had deformed from all the pressure exerted trying to activate the sticking latch mechanism. The picture below is the drivers door. The passenger door cam was deformed even further and would not push the latch. If I had waited much longer I would have been "locked" out of the car!
I replaced the cams and after a thorough cleaning of the latch mechanisms (and new grease) the doors operate like new. This is a really simple project and I did four doors in about 3.5 hours. That was taking my time and doing other stuff while waiting for the degreaser to work.
So, if your door latches are sticking, don't put off this project. It's easy and very rewarding!
euro911
post Jul 15 2013, 02:15 PM
Mark, I'm pretty sure I'm going to need at least TWO of them. I'll add them to my existing order list and get the payment off to you ASAP.
billh1963   Door latch repair.....   Jul 13 2013, 02:34 PM
stugray   Cmon, truthfully... how long did you spend just ...   Jul 13 2013, 03:35 PM
billh1963   Cmon, truthfully... how long did you spend just...   Jul 13 2013, 04:11 PM
bulitt   I like to use diesel fuel. dunk them in and hit t...   Jul 13 2013, 03:41 PM
jesiv   I like to use diesel fuel. dunk them in and hit ...   Jul 17 2013, 08:31 PM
JawjaPorsche   Good Info! :beer2:   Jul 13 2013, 04:23 PM
cary   Gunk is the only thing I that I could find to cut ...   Jul 13 2013, 08:00 PM
euro911   Thanks for posting, Bill ... I need to perform thi...   Jul 13 2013, 11:20 PM
balljoint   Where are the cams available new?   Jul 14 2013, 06:35 AM
billh1963   Where are the cams available new? AA has replac...   Jul 14 2013, 07:54 AM
bdstone914   Where are the cams available new? AA has repla...   Jul 17 2013, 09:14 PM
dr914@autoatlanta.com   the very first aftermarket 914 part we ever made w...   Aug 11 2020, 09:00 AM
Root_Werks   the very first aftermarket 914 part we ever made ...   Aug 11 2020, 09:14 AM
euro911   Are they available through 914rubber.com too?   Jul 14 2013, 11:35 AM
JawjaPorsche   Are they available through 914rubber.com too? ...   Jul 14 2013, 11:43 AM
Mikey914   Are they available through 914rubber.com too? ...   Jul 15 2013, 09:04 AM
billh1963   [quote name='JawjaPorsche' post='1895041' date='J...   Jul 15 2013, 12:45 PM
Mikey914   [quote name='JawjaPorsche' post='1895041' date='...   Jul 15 2013, 08:29 PM
Philip W.   [quote name='billh1963' post='1895470' date='Jul ...   Jul 16 2013, 09:09 AM
JmuRiz   Good info, I need to tackle this once my car is ba...   Jul 14 2013, 02:36 PM
green914   I should do this on mine too. Used to have a lot o...   Jul 15 2013, 11:04 AM
euro911   Mark, I'm pretty sure I'm going to need at...   Jul 15 2013, 02:15 PM
stugray   While you are at it....... http://www.914world.co...   Jul 15 2013, 02:32 PM
JmuRiz   Wish I had a parts washer, what type of container ...   Jul 15 2013, 06:15 PM
billh1963   Wish I had a parts washer, what type of container...   Jul 15 2013, 06:19 PM
euro911   Wish I had a parts washer, what type of container ...   Jul 15 2013, 06:42 PM
lonewolfe   What is the prefered grease on these door latch pa...   Jul 18 2013, 04:18 AM
billh1963   What is the prefered grease on these door latch p...   Jul 18 2013, 04:40 AM
Philip W.   What is the prefered grease on these door latch ...   Jul 18 2013, 05:46 AM
macmike83151@yahoo.com   Hello there, Are there any tips or tricks to getti...   Nov 25 2019, 01:32 PM
Mikey914   Hello there, Are there any tips or tricks to gett...   Nov 26 2019, 06:51 PM
90quattrocoupe   I have found the motorcycle chain lube works prett...   Nov 26 2019, 02:16 PM
Mark Henry   Just did my passenger door, the cam had been broke...   Nov 26 2019, 10:00 PM
Mikey914   Yes, It is why these bend. Hopefully before the me...   Nov 27 2019, 01:28 AM
sixnotfour   Yes, It is why these bend. Hopefully before the m...   Nov 27 2019, 04:30 AM
AZBanks   Both door locks on my car were so hard to turn tha...   Mar 2 2020, 03:39 AM
mepstein   Both door locks on my car were so hard to turn th...   Mar 2 2020, 07:12 AM
AZBanks   Both door locks on my car were so hard to turn t...   Mar 2 2020, 11:11 AM
mepstein   [quote name='mepstein' post='2790750' date='Mar 2...   Mar 2 2020, 12:06 PM
cary   What Mark said. Don't procrastinate. I know ta...   Mar 2 2020, 09:19 AM
dr914@autoatlanta.com   years ago, aware of the problem with the broken do...   Mar 2 2020, 01:02 PM
Root_Werks   Searching and found this thread (closest to what I...   Aug 10 2020, 02:25 PM
mepstein   Searching and found this (closest to what I'm...   Aug 10 2020, 03:35 PM
euro911   Go to an ACE Hardware store and peruse their O-Rin...   Aug 10 2020, 02:38 PM
Root_Werks   Here's a picture of them:   Aug 10 2020, 04:06 PM
FlacaProductions   https://914rubber.com/aluminum-door-lock-cylinder-...   Aug 10 2020, 07:37 PM
Mikey914   Thanks Brian, yes that is it. Yes the original was...   Aug 10 2020, 09:24 PM
Root_Werks   Perfect, thanks! After clicking the link, fou...   Aug 11 2020, 08:32 AM
euro911   Not sure what I was thinking ... then it hit me - ...   Aug 11 2020, 10:44 AM
Root_Werks   Not sure what I was thinking ... then it hit me -...   Aug 11 2020, 11:24 AM
8 User(s) are reading this topic (8 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 6th January 2025 - 05:33 PM
