> My 2.4 Six Engine, Manufacturing prototype intake adapters.
McMark
post Jul 15 2013, 07:30 PM
914 Freak!
I picked up this 2.4 six awhile back and I'm gonna use this thread as I develop the engine which will eventually go in my gold car.
I'm starting a little out of order, but too bad. (IMG:style_emoticons/default/tongue.gif)
So I have this aluminum flywheel. No manufacturer stamps or numbers on it whatsoever. I'm thinking that it might be too light for a street car, so I may not use it. It's about 3lbs by itself. I've got a 914 clutch adapter (basically a cut down 914/4 flywheel that bolts to the outer edge) and that brings the total flywheel weight to about 10lbs.
I want a streetable car, is this thing too light?
sixnotfour
post Jul 15 2013, 08:04 PM
your right at a stock 2.0 6 cylinder flywheel weight.. do you have an aluminum pressure plate the would be great, unless its for a LIMO, Then get a cast iron anchor..
McMark   My 2.4 Six Engine   Jul 15 2013, 07:30 PM
ConeDodger   Try it...   Jul 15 2013, 07:37 PM
BKLA   :agree: I have a lightened Patrick Motorsports f...   Jul 15 2013, 07:47 PM
sixnotfour   your right at a stock 2.0 6 cylinder flywheel weig...   Jul 15 2013, 08:04 PM
brant   old and new flywheels of course we don't have...   Jul 15 2013, 10:46 PM
sixnotfour   oh Brant that aluminum one is real vintage alright...   Jul 15 2013, 10:48 PM
brant   its Frank Becks toss off..... he went to a 4.5 di...   Jul 15 2013, 10:49 PM
pcar916   I've had a 6.75lb Patrick Motorsports aluminum...   Jul 16 2013, 03:48 PM
biosurfer1   Too light? I think you just killed a little part o...   Jul 16 2013, 04:08 PM
get off my lawn   how light is your flywheel? I'd say it's ...   Jul 18 2013, 10:39 AM
ChrisNPDrider   My daily driver 914 turned cafe racer AX weekend w...   Jul 19 2013, 10:20 AM
GeorgeRud   Figure that the heavy outer starter ring is at the...   Jul 19 2013, 10:29 AM
McMark   Cool. Sounds like this flywheel will be fine. I ...   Jul 19 2013, 11:26 AM
JmuRiz   With a 2.4 I'd go with longer to get a smidge ...   Jul 19 2013, 12:04 PM
BKLA   :agree: Love the polaris TB's! Great Ide...   Jul 19 2013, 02:32 PM
scotty b   What cams are you using ? :confused:   Jul 19 2013, 03:22 PM
Dave_Darling   Remember that the factory went to high-butterfly t...   Jul 19 2013, 03:37 PM
kg6dxn   Longer runners will give you better low end torque...   Jul 19 2013, 06:23 PM
McMark   Street engine. I like torque.   Jul 19 2013, 06:41 PM
r_towle   2 flanges cut. Two pieces of tubing, cut stretched...   Jul 19 2013, 08:37 PM
JmuRiz   Carbs for up to 3.0 are typically 40, but this siz...   Jul 19 2013, 09:15 PM
McMark   Okay, time for another thought/question. The engi...   Jul 26 2013, 08:08 PM
Mark Henry   Okay, time for another thought/question. The eng...   Jul 26 2013, 09:51 PM
kg6dxn   Open it! You know you want to. DO IT!...   Jul 26 2013, 09:40 PM
rick 918-S   Do a leak down first and make sure you "need ...   Jul 26 2013, 10:02 PM
McMark   It's more about knowing what heads, cams, pist...   Jul 27 2013, 02:58 AM
Gary   Hey Mark - is this the motor I dropped off? If so,...   Jul 27 2013, 04:00 AM
Eric_Shea   What does this mean? a. Port size 36X35 38mm int...   Jul 27 2013, 10:14 AM
sixnotfour   that configuration only has about 8-1 compression....   Jul 27 2013, 10:33 AM
Dr Evil   :popcorn:   Jul 27 2013, 11:22 AM
Trekkor   Bolt on a set of carbs and run it on the test stan...   Jul 27 2013, 10:16 PM
McMark   The $2500 carbs I don't have? :blink: L...   Aug 5 2013, 11:30 PM
Trekkor   The $2500 carbs I don't have? :blink: ...   Aug 9 2013, 03:25 PM
McMark   Finished the intake drawing (I think). Now I need...   Aug 9 2013, 01:15 AM
jimkelly   will those Polaris fuel injectors provide enough f...   Aug 9 2013, 06:48 AM
McMark   The injectors are pretty standard. So I was alrea...   Aug 9 2013, 10:39 AM
polo classic   Do you know what distance is from the throttle bod...   Aug 9 2013, 12:33 PM
McMark   Not sure. I drew up 'shorties' because on...   Aug 9 2013, 01:59 PM
McMark   Ahhh, thats makes more sense. ;) I expect it runs....   Aug 9 2013, 04:29 PM
McMark   Prototype printing underway (not by me). :boing:   Aug 9 2013, 07:28 PM
McMark   All done an ready to ship to me. :boing:   Aug 9 2013, 11:09 PM
euro911   Cool. What is the material, Mark?   Aug 10 2013, 01:09 AM
jimkelly   why the groove seen from top? is it a two piece p...   Aug 10 2013, 04:17 AM
jpnovak   I hope Mark doesn't mind my response. I am pr...   Aug 10 2013, 06:18 AM
Krieger   Very cool to see the cutting edge printing edge a...   Aug 10 2013, 09:27 AM
McMark   Thanks for chiming in Jamie. I didn't know if...   Aug 10 2013, 09:39 AM
polo classic   Did you ever consider using Boxster/997/996 parts,...   Aug 22 2013, 02:43 PM
McMark   Cool! Hadn't seen that. I'd like to t...   Aug 22 2013, 05:23 PM
tscrihfield   This looks very cool! What are you going to h...   Aug 22 2013, 05:37 PM
McMark   If the prototype adapters work ill send the CAD fi...   Aug 22 2013, 06:24 PM
jcd914   If the prototype adapters work ill send the CAD f...   Aug 22 2013, 08:02 PM
edwin   This part has "home cast aluminium" writ...   Aug 23 2013, 07:12 AM
veekry9   This part has "home cast aluminium" wri...   Oct 27 2013, 04:15 PM
rhodyguy   home cast? as in a garage?   Aug 23 2013, 07:24 AM
McMark   Actually I do. Casting has been on my todo list fo...   Aug 23 2013, 08:01 AM
jbyron   Looking at the pic, I'm concerned whether or n...   Aug 23 2013, 09:38 AM
GeorgeRud   Yeah, it does look like you might have to lift it,...   Aug 23 2013, 06:20 PM
McMark   George is thinking along the same lines as me. ;) ...   Aug 23 2013, 06:29 PM
McMark   Quick update... Intake manifolds are at the machi...   Oct 26 2013, 10:59 PM
tscrihfield   Quick update... Intake manifolds are at the mach...   Oct 26 2013, 11:28 PM
veekry9   This is Great. Thanks for showing the World the la...   Oct 27 2013, 03:49 PM
sixnotfour   These are mine. A little different from Mark...   Nov 8 2013, 02:03 PM
914Timo   These are mine. A little different from Mark...   Nov 9 2013, 12:16 PM
McMark   Wow, looks great. Perfect timing, cause I just go...   Nov 8 2013, 04:14 PM
jimkelly   absolutely beautiful :wub:   Nov 8 2013, 04:15 PM
sixnotfour   sweet !! How are you adjusting the 2mm ...   Nov 8 2013, 04:59 PM
McMark   TBD. I should actually have them in my hands in a...   Nov 8 2013, 06:08 PM
sixnotfour   mine are machined aluminum, with the flanges welde...   Nov 9 2013, 04:06 PM
jpnovak   Those look great!   Nov 9 2013, 08:31 PM
rick 918-S   Nice projects :beer2:   Nov 9 2013, 10:59 PM
sixnotfour   :beer2:   Nov 17 2013, 03:52 PM
Dave_Darling   It looks cool, but what's the perforated metal...   Nov 17 2013, 10:48 PM
McMark   Those are Jeffs, but it's a mount. It ties th...   Nov 17 2013, 11:07 PM
ConeDodger   Those are Jeffs, but it's a mount. It ties t...   Nov 18 2013, 10:04 AM
sixnotfour   Those are Jeffs, but it's a mount. It ties ...   Nov 18 2013, 02:43 PM
McMark   Here's my adapters. Got a sample piece in bar...   Nov 18 2013, 12:13 PM
Series9   I REALLY like it! :beer2:   Nov 18 2013, 12:21 PM
JmuRiz   Very cool stuff, definitely keeping my eye on this...   Nov 18 2013, 12:31 PM
30 User(s) are reading this topic (30 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 29th December 2024 - 12:16 PM
